Windows 10: Laptop randomly shutdown with beep sound and charging indicator problem.
Discus and support Laptop randomly shutdown with beep sound and charging indicator problem. in Windows 10 BSOD Crashes and Debugging to solve the problem; Hey, In few days my laptop is randomly shuts down with beep sound. It also have a battery indicater problem its turning contiously white and orange... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by PiyushSharma_99, Aug 19, 2020.
  1. Laptop randomly shutdown with beep sound and charging indicator problem.
    Hey, In few days my laptop is randomly shuts down with beep sound. It also have a battery indicater problem its turning contiously white and orange again and again, when it turns white is not charging then turns orange it's start charging. I also tried battery removal process but nothing happened. Please help.
  2. Laptop no longer charging since Windows 10 update
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    Laptop randomly shutdown with beep sound and charging indicator problem. pbDp4sx.png
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Aug 19, 2020
  3. Akihiko Win User
    Thanks for the response, but the issue is not the battery or the laptop. It was charging and working fine prior to this most recent Windows 10 update.
    I'm sorry, I don't understand what you're trying to say. When the charger is plugged in, it just says "plugged in", but my battery has been at 2% for the past several hours. Obviously the charger is doing something since it's holding the 2% power, but it's not charging. There has to be some day to bypass whatever this update broke.
    Akihiko, Aug 19, 2020
  4. Laptop randomly shutdown with beep sound and charging indicator problem.
    Battery Won't Charge Fully
    Step 1
    Step 2
    Step 3
  1. Laptop randomly shutdown with beep sound and charging indicator problem. - Similar Threads - Laptop randomly shutdown
  2. Beep sound in laptop
    Beep sound in laptop: When my laptop is in sleep mode and then I turn it on by doing random clicks , my laptop makes a four-beep sound And this beep sound also happens sometimes when I am using my Dell laptop It has been only 2 months since I bought the laptop At that time it did not make any beep...
  3. Beep sound in laptop
  4. Charge Beep
    Charge Beep: Hello. In my acer laptop, whenever I plug my charger, it makes a beep. It is not a problem as it is a feature. But I want to remove it. How do I? I have a Windows 11 pc. Thanks in advanceAcer Aspire A315-7GProcessor : IntelR CoreTM i7-1065G7 CPU @ 1.30GHz 1.50 GHz Installed...
  5. Charge Beep
  6. Charging indicator issue
    Charging indicator issue: The pop-up saying "battery is low" blinking on my screen when the charge is very low. It vanishes when the battery charge goes to about 10%. When I am playing games this indicator is blinking as well until the game freezes...
  7. Random Mouse lagging And beeping sound
    Random Mouse lagging And beeping sound: Random mouse beeps and lag randomly happen whatever I am doing on my PC, especially when clicking fast, not my mouse as issue happens whatever mouse I seem to use. Started happening a couple months ago. Specs: Omen Laptop GTX 1060 6GB I5 8GB DDR4...
  8. battery not charging indicator
    battery not charging indicator: Hello. Not sure which topic this should be posted under; please redirect me if need be. After updating a couple of days ago, the battery indicator says "XX% available (plugged in, not charging). I tested the battery and there doesn't appear to be any fault. I'm guessing...
  9. Random Shutdowns and Turn Ons But Not Indicative of Hardware Failure
    Random Shutdowns and Turn Ons But Not Indicative of Hardware Failure: The problem I'm having is extremely unusual. It's not just that my PC shuts down randomly. It turns on randomly as well. That said, there's more to it than that. It shuts down as if I'd prompted it to shut down. If I leave an unsaved notepad document open, it stops the...
  10. shutdown sound problem
    shutdown sound problem: I have adjusted registry to allow access to system exit sound, which, by default in win10, is not visible. Having made it visible, even when I change to my preferred wav file, apply it, and play it for confirmation, when I shutdown, I hear only the ms default ding. I am able,...
