Windows 10: Left-handed touchpad tap and double-tap is not working.
Discus and support Left-handed touchpad tap and double-tap is not working. in Windows 10 Gaming to solve the problem; I have gone to my mouse settings and switched it to being left-handed. I also made sure that "Switch primary and secondary buttons" is checked in the... Discussion in 'Windows 10 Gaming' started by Tawny812, Feb 21, 2022.
Left-handed touchpad tap and double-tap is not working. - Similar Threads - Left handed touchpad
in Windows 10 Drivers and HardwareLeft-handed touchpad tap and double-tap is not working.: I have gone to my mouse settings and switched it to being left-handed. I also made sure that "Switch primary and secondary buttons" is checked in the "additional mouse settings". The "touchpad settings" only has a sensitivity option.The buttons on the bottom of the touchpad... -
in Windows 10 Software and AppsLeft-handed touchpad tap and double-tap is not working.: I have gone to my mouse settings and switched it to being left-handed. I also made sure that "Switch primary and secondary buttons" is checked in the "additional mouse settings". The buttons on the bottom of the touchpad have switched correctly, but now when I double-tap the... -
Touchpad double tap issue...
in Windows 10 CustomizationTouchpad double tap issue...: I have acer aspire 3 a315-33-c89l it's touchpad supports 5+ fingers tap but after a update it supporting only one finger tap. When i tried to change setiings, setting only shows sensitivity of touchpad...[ATTACH] Before it shows many gestures and settings...i tried to... -
Tap in the touchpad is not working
in Windows 10 Drivers and HardwareTap in the touchpad is not working: In my laptop tap option is not working. https://answers.microsoft.com/en-us/windows/forum/all/tap-in-the-touchpad-is-not-working/3851af51-b211-46e7-87f0-9bd271009b33 -
Double Tap
in Windows 10 CustomizationDouble Tap: When I want to "enter" something and I tap that key, it always returns to the same empty space and I have to re-enter and tap "enter" again. What can cause that? It is annoying.... -
How to disable double tap on touchpad
in Windows 10 CustomizationHow to disable double tap on touchpad: After this new Windows 10 update I cannot find the settings to turn off touchpad double tap feature. Its annoying that Microsoft has changed the layout of windows when there was no need to. Before the update is was very easy to do. Please can someone show me how to turn... -
Touchpad Tap not working
in Windows 10 Drivers and HardwareTouchpad Tap not working: After using Bluetooth mouse, touch pad tapping has stopped working, navigation is working fine, Its Synaptics clik pad V7.4. I tried to update the driver, but it shows the driver is up to date.............. Please help...... 31536 -
Dell XPS12, 10130, touchpad double tap not working
in Windows 10 Drivers and HardwareDell XPS12, 10130, touchpad double tap not working: Hi all. Using 10130 dual booted with 8.1 on an XPS12. I have the latest available driver which admittedly is over a year old. The touchpad does not recognise double tap to activate, such as when trying to move into a folder in explorer. I've been through every option,... -
Left Click & double tap not working in windows 10!
in Windows 10 SupportLeft Click & double tap not working in windows 10!: Hello, I use a HP laptop & since the last few days I am not able to open any files or click on something since the left (main) key & double tap on the mouse pad are not working! Although I am able to move the cursor/pointer over the touch pad & the right click is working fine...
