Windows 10: Location totally wrong on wired network connection but OK on wifi using same router
Discus and support Location totally wrong on wired network connection but OK on wifi using same router in Windows 10 Network and Sharing to solve the problem; Hello! I have Windows 10 PC and Windows 7 PC connected to router via cable and Windows 7 notebook and smartphones connected to same router via WiFi.... Discussion in 'Windows 10 Network and Sharing' started by serb1982, Dec 17, 2018.
Location totally wrong on wired network connection but OK on wifi using same router - Similar Threads - Location totally wrong
Wired Network connection.
in Windows 10 GamingWired Network connection.: Back in the early 2000’s, I ran ethernet to multiple computers in my house. For a while I was able to use it to do a lot of file and printer sharing in the home network, but for the last few years it’s been a lot more iffy, and I’m currently looking at my new Windows 11... -
in Windows 10 Software and AppsWired Network connection.: Back in the early 2000’s, I ran ethernet to multiple computers in my house. For a while I was able to use it to do a lot of file and printer sharing in the home network, but for the last few years it’s been a lot more iffy, and I’m currently looking at my new Windows 11... -
Connection to WiFi router
in Windows 10 Network and SharingConnection to WiFi router: I installed a Wi-Fi adaptor card on my Motherboard. I disabled the onboard WiFi adaptor.In Control Panel/Internet Options/Connections I cannot find the full panel to edit/enter info to allow the new card to find my router.I conclude that I have missed a step, or do not... -
Wired In Connection on a modem router Combo
in Windows 10 GamingWired In Connection on a modem router Combo: i need immediate assistance trying to get my my ethernet cable to work on my computer it doesnt connect at all and i have XTREME mediacom high speed internet. i tried uninstalling and re installing the drivers and it isnt working. any forward knowledge on troubleshooting... -
Problem Connecting Multiple Wifi Routers With Same SSID
in Windows 10 Network and SharingProblem Connecting Multiple Wifi Routers With Same SSID: Hi, I lives in Pakistan, Here main BroadBand service provider is PTCL. When they install new BroadBand internet connection, they name each router's SSID as "PTCL-BB". Surely, I can change the SSID but as we go to some other place same problem exists. I need to use some... -
Wired and WIFI Networks
in Windows 10 Network and SharingWired and WIFI Networks: Helloooo! I hope everyone is happy and healthy during these strange times! This is my first post, and I am a relative noob, so please be gentle :) I fully expect I might need to get someone in, for this problem. I am not trying avoid paying anyone. But seeing as I cant get... -
Connecting to Router/WIfi
in Windows 10 Network and SharingConnecting to Router/WIfi: I can not connect to my Router/Modem at all. I have tried everything there is to be able to connect. I did get a msg come up from Microsoft that said problem was with Microsoft & to try back later. That was 2 days ago. Thank you... -
MY LOCATION IS TOTALLY WRONG HELP
in AntiVirus, Firewalls and System SecurityMY LOCATION IS TOTALLY WRONG HELP: IN MY SETTING MY LOCATION RIGHT BUT IN MY MICROSOFT ACCT. UNDER FIND MY DEVICE IT IS SHOWING MY LOCATION ON THE OTHER SIDE OF THE WORLD AND I CANT CHANGE IT WINDOW10 64 BIT AND YES WINDOWS IS UP -TO-DATE I USE CHROME AND IT IS UP-TO-DATE I HAVE ALSO HAD MICROSOFT REMOTE... -
How to setup a wired network between routers
in Windows 10 Network and SharingHow to setup a wired network between routers: Hi there I am trying to set up a wired network with the following: Main router linked to internet = Asus DSL N66U with IP set to 192.168.1.1 (network 1) I have then wired a link to the following Tenda wireless N300 Router IP 192.168.1.1 (network 2) I was not able to add...
