Windows 10: low battery keeps shutting down my computer. The problem is I don't have a battery.
Discus and support low battery keeps shutting down my computer. The problem is I don't have a battery. in Windows 10 Performance & Maintenance to solve the problem; I have Windows 10 Pro ver. 1909. IT is up to date. Low battery keeps shutting down my computer. The problem is I don't have a battery. The computer... Discussion in 'Windows 10 Performance & Maintenance' started by John Barbee1, Feb 26, 2020.
low battery keeps shutting down my computer. The problem is I don't have a battery. - Similar Threads - low battery keeps
Laptop Shuts Down a second before it displays "Battery low"
in Windows 10 BSOD Crashes and DebuggingLaptop Shuts Down a second before it displays "Battery low": Hello, I had turned off hibernation a week before. Since then, whenever it gets a low battery, my laptop shuts down automatically earlier it used to hibernate, so at least I could get my things back. What to do so that the warning comes before the laptop shuts down.Thank you!... -
Laptop shutting down without warning for low battery
in Windows 10 Performance & MaintenanceLaptop shutting down without warning for low battery: I am having an issue with my laptop since it shuts down when battery is low but there is no low battery popup to indicate.Moreover if i change the power plan setting and set the laptop to sleep when battery is below 15% it still don't work and laptop just shuts down. I am... -
in Windows 10 GamingLaptop shutting down without warning for low battery: I am having an issue with my laptop since it shuts down when battery is low but there is no low battery popup to indicate.Moreover if i change the power plan setting and set the laptop to sleep when battery is below 15% it still don't work and laptop just shuts down. I am... -
in Windows 10 Software and AppsLaptop shutting down without warning for low battery: I am having an issue with my laptop since it shuts down when battery is low but there is no low battery popup to indicate.Moreover if i change the power plan setting and set the laptop to sleep when battery is below 15% it still don't work and laptop just shuts down. I am... -
Battery Goes To Zero After Restarting/Shutting Down At Low Battery Level.
in Windows 10 Performance & MaintenanceBattery Goes To Zero After Restarting/Shutting Down At Low Battery Level.: I bought this laptop about a month ago, and this problem occurred for the first time 6 days ago. I have tried disabling fast startup, hibernation mode, and I even perform full shutdown shutdown /s /f /t 0, it doesn't seem to work at all.I can confirm there's nothing that uses... -
Laptop shuts down at low battery warning
in Windows 10 BSOD Crashes and DebuggingLaptop shuts down at low battery warning: This started a week or two ago, where instead of my laptop giving me the low battery warning, and I can continue to use it after I plug it in, it just shuts down instead of giving me said warning. Any way to fix this?... -
Blue screen "Battery Low" Locks/shuts down laptop. On restarting, battery is 99%.
in Windows 10 BSOD Crashes and DebuggingBlue screen "Battery Low" Locks/shuts down laptop. On restarting, battery is 99%.: I know this type of issue has been raised a lot but the post I found was quite old. I'm hoping someone has found out how to stop this happening. I have replaced the battery because at one stage the battery diagnostic showed the battery to be failing and a friend replaced... -
laptop shutting down before battery is low
in Windows 10 Installation and Upgradelaptop shutting down before battery is low: laptop shutting down before battery is low how to fix this. This happened after windows update :-( https://answers.microsoft.com/en-us/windows/forum/all/laptop-shutting-down-before-battery-is-low/da7da672-6d86-4a85-9f8f-8b853dee86f4 -
Shut down computer when on battery
in Windows 10 SupportShut down computer when on battery: Hello, I need to be able to shut down my ASUS R517S laptop whenever it is running on battery (which is internal and cannot be removed easily). OS: Windows 10 Home. Why? Working in a offshore environment with a...
whats the solution when your pc boots and says battery is critical low and shutdown
