Windows 10: Major problems and System problems
Discus and support Major problems and System problems in Windows 10 BSOD Crashes and Debugging to solve the problem; Hello people, Is the black screen a bug or a major problem? Will Microsoft will fix the problem in the next update in 2021? I would to suggest to... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Nicolaj1986, Dec 4, 2020.
Major problems and System problems - Similar Threads - Major problems System
Major problem to me
in Windows 10 Updates and ActivationMajor problem to me: Why won't my product key work? when i typed the command on the command prompt and copied my windows 10 product key then typed it in thechange product key it still does not work can somebody help me with this problem its all messed up right now... -
MAJOR OneDrive Problems!!!
in Windows 10 Network and SharingMAJOR OneDrive Problems!!!: I don't think I have been this angry in years. I always keep a few select documents in the OneDrive folder. I want on OneDrive very few of my documents, very very few of my photos, and NONE of my music. Apparently a recent Windows Update decided to put just about everything... -
Major problem.
in Windows 10 Ask InsiderMajor problem.: Windows can't sign into my account although I have been using it for 3+years. I have tried almost every solution I could find on the internet and restarted my pc several times. It just keeps on logging me into a temporary user profile and repeats that it's unable to sign in... -
Windows Update - Major Problem!
in Windows 10 Installation and UpgradeWindows Update - Major Problem!: Hi, I've been getting messages in Windows 10 for a couple of months to complete an update before November or I will fall out of support. I have attempted A few times without success and decided to try again today. I triggered to update, at around 24% the machine restarted... -
Major Problem with Computer
in Windows 10 BSOD Crashes and DebuggingMajor Problem with Computer: My grandparents have an asus g11 gaming computer that they brought to their house a couple years ago. When the hurricane was coming for FL in September 2017 we moved across the state in hopes that we won't get killed. The aftermath was that my grandparent's house had no power... -
I have a major problem
in Windows 10 GamingI have a major problem: Okay, so this is a big problem. I got a windows 10 about a few days ago to play and stream games online. Though, my windows is super laggy when I play games at all. My audio glitches and my fps is always super low. I have no idea how to fix the problem as I've never owned a... -
Major problem
in AntiVirus, Firewalls and System SecurityMajor problem: amazon says I have been hacked by North Korea they say only micro soft can fix and they want 500 dollars what can I do please help me 112044 -
Major Update Problems
in Windows 10 Updates and ActivationMajor Update Problems: The last major update (early December) downloaded and installed without errors or problems. Upon starting the PC the following day, I found extra icons on my desktop, start menu with extra icons, and many apps that I had previous remove reinstalled. But worst of all, all my... -
Major Booting Problems
in Windows 10 SupportMajor Booting Problems: I tried to install W10 on a second hard drive while my main HD was connected. Major problems now. I could not reboot my main HD, and I could not boot my second drive. I wiped my second HD and tried to install W10 again, but no luck. Tried to repair my main HD with a...
