Windows 10: microsft edge high cpu usage and high power
Discus and support microsft edge high cpu usage and high power in Windows 10 BSOD Crashes and Debugging to solve the problem; so when I use Microsoft edge it goes to high power and high cpu usage up to like 60% even sometimes 70% is there something I can do... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by jasondodd2, Dec 2, 2019.
microsft edge high cpu usage and high power - Similar Threads - microsft edge high
CPU usage is high
in Windows 10 Software and AppsCPU usage is high: My CPU usage is 50% and sometimes higher and the only thing I have opened is Google Chrome. Presentational font cache exe is using most of it and Chrome is using 10-15%. Memory usage is 60% and Chrome is using most of that. 960 mb What can I do to fix this?... -
high cpu and power usage
in Windows 10 BSOD Crashes and Debugginghigh cpu and power usage: Hello, from tomorrow after upgrading sata ssd, I install windows in my new ssd and then start my laptop then i saw that my laptop was using system and system interrupts service continuosly. It's not ending, I also wait 6hrs but it's not ending. When i was using hdd my lower... -
in Windows 10 Gaminghigh cpu and power usage: Hello, from tomorrow after upgrading sata ssd, I install windows in my new ssd and then start my laptop then i saw that my laptop was using system and system interrupts service continuosly. It's not ending, I also wait 6hrs but it's not ending. When i was using hdd my lower... -
in Windows 10 Software and Appshigh cpu and power usage: Hello, from tomorrow after upgrading sata ssd, I install windows in my new ssd and then start my laptop then i saw that my laptop was using system and system interrupts service continuosly. It's not ending, I also wait 6hrs but it's not ending. When i was using hdd my lower... -
High CPU Usage
in Windows 10 BSOD Crashes and DebuggingHigh CPU Usage: I just did a factory reset of my windows 10 because of low storage and an issue I have had before and after the reset is high CPU usage. I don't have any external anti virus. And when I get the high usage I just have to open task manager and its fine. its not even when I play... -
High CPU usage
in Windows 10 BSOD Crashes and DebuggingHigh CPU usage: I have constant ongoing high CPU usage . One of the causes is a non Windows app I'm trying to rectify. The other 3 are all Windows based; WMI provider host, Antimalware Service and Services and Controller App.... -
High cpu usage
in Windows 10 BSOD Crashes and DebuggingHigh cpu usage: Hi guys, I have a weird problem and I can't fix it. After changing some settings in Comand Promt my computer started behaving weird. My cpu usage is high and very unstable, for no reason. In the task manager there is nothing that should cause high cpu usage, there are no... -
microsoft edge high cpu usage
in Windows 10 BSOD Crashes and Debuggingmicrosoft edge high cpu usage: ok when I open Microsoft edge and when im doing simple task the cpu usage goes high so can anybody help me fix this problem https://answers.microsoft.com/en-us/windows/forum/all/microsoft-edge-high-cpu-usage/76783c6f-8e1f-464d-a54d-8b25f14db765 -
HIGH POWER USAGE WITH MICROSOFT EDGE
in Windows 10 BSOD Crashes and DebuggingHIGH POWER USAGE WITH MICROSOFT EDGE: Why is my Microsoft Edge using so much power? My CPU fan is going nuts! [ATTACH] https://answers.microsoft.com/en-us/windows/forum/all/high-power-usage-with-microsoft-edge/3c96abf8-257d-47ee-a5bd-c0261f2a319f
edge creates high power usage on my all in one
