Windows 10: monitor dimming after 7 seconds - power options checked.
Discus and support monitor dimming after 7 seconds - power options checked. in Windows 10 Software and Apps to solve the problem; I have a LENOVO ThinkCenter with a LG FLATRON L192ws monitor. I have set the monitor to 10 min. , it still is dimming after 7 sec.... Discussion in 'Windows 10 Software and Apps' started by Leif HelgeWesetrud, May 27, 2020.
monitor dimming after 7 seconds - power options checked. - Similar Threads - monitor dimming seconds
Primary Monitor Dims When Connecting Second Monitor
in Windows 10 Software and AppsPrimary Monitor Dims When Connecting Second Monitor: I'm currently using an LG 34UC79G-B monitor as my primary display and a Samsung CF390 as my secondary display, running Windows 11.When the LG is utilized as the sole monitor display settings set to "Only Show on 1", the monitor works fine, brightness is great. However, when I... -
in Windows 10 GamingPrimary Monitor Dims When Connecting Second Monitor: I'm currently using an LG 34UC79G-B monitor as my primary display and a Samsung CF390 as my secondary display.When the LG is utilized as the sole monitor display settings set to "Only Show on 1", the monitor works fine, brightness is great. However, when I switch to "Extend... -
Monitor Dims when second monitor is selected
in Windows 10 GamingMonitor Dims when second monitor is selected: I have 2 monitors identical View Sonic devices Recently when I select a program on one of the monitors, the other monitor goes dim. If I select a program on the second monitor, the unselected monitor first monitor goes dim. The interesting thing is that if I log in as the... -
in Windows 10 Software and AppsMonitor Dims when second monitor is selected: I have 2 monitors identical View Sonic devices Recently when I select a program on one of the monitors, the other monitor goes dim. If I select a program on the second monitor, the unselected monitor first monitor goes dim. The interesting thing is that if I log in as the... -
in Windows 10 CustomizationMonitor Dims when second monitor is selected: I have 2 monitors identical View Sonic devices Recently when I select a program on one of the monitors, the other monitor goes dim. If I select a program on the second monitor, the unselected monitor first monitor goes dim. The interesting thing is that if I log in as the... -
Screen dimming after 20 seconds
in Windows 10 SupportScreen dimming after 20 seconds: This just started today, but my laptop screen dims every 20 seconds if I'm not doing anything. Doesn't matter if I'm gaming, watching a video or whatever, if there's no mouse movement or key strokes, the screen dims from it's highest to lowest setting without fail. I've tried... -
Dim second monitor on login
in Windows 10 Ask InsiderDim second monitor on login: I am experiencing a bug where my second monitor is dim after logging in about half of the time. I believe this is a software issue because the cursor (and only the cursor) is at the correct brightness. Taking desktop screenshots also shows correct brightness in the image. I... -
Dual monitors - the second monitor is very dim
in Windows 10 CustomizationDual monitors - the second monitor is very dim: I have a Windows 10 PC, with two displays, a 1080p Lenovo monitor and a Samsung UHD TV. The Lenovo is my main PC monitor. In settings, when I set the monitor to the Lenovo only, the display is fine; when I set the monitor to the Samsung only, the display is fine. When I... -
Desktop "auto dimming" - not power option related
in Windows 10 CustomizationDesktop "auto dimming" - not power option related: This isn't the first time I've had this issue, and not sure how it was resolved last time. The desktop icons are "dimmed" and light up when I click on the start menu. This is particularly difficult for me as I'm visually impaired and brightness/contrast levels are crtitical....
