Windows 10: Monitors will not turn off per power settings
Discus and support Monitors will not turn off per power settings in Windows 10 Performance & Maintenance to solve the problem; My monitors do not enter power save, per my power settings. I've run troubleshooter, reset to default, changed settings, updated drivers, checked... Discussion in 'Windows 10 Performance & Maintenance' started by X Spearmint, Jan 3, 2020.
Monitors will not turn off per power settings - Similar Threads - Monitors turn off
Power setting turns display off as set but then it turns right back on
in Windows 10 SupportPower setting turns display off as set but then it turns right back on: Windows 10 version 20H2 (OS Build 19042.1110) I have a Dell Inspiron 7700 All-in-One computer. I have the power setting set to turn off display in 10 minutes and the put the computer to sleep set to never. After 10 minutes of no activity the screen turns off but then turns... -
Monitor powers on after computer turns it off
in Windows 10 Performance & MaintenanceMonitor powers on after computer turns it off: Trying to find how to keep monitor off after I lock the PC. What I do: 1. Monitor powers off after 1 minute when PC is locked 2. In few seconds computer plays sound like it detects new hardware, monitors wakes up and shows "No Cable Connected". 3. Then monitor turns off.... -
Laptop monitor doesn't turn back on after automatically turning off due to power settings.
in Windows 10 Ask InsiderLaptop monitor doesn't turn back on after automatically turning off due to power settings.: One of the laptops I have has been having this issue for a long time. I've had it for about 2 years now and it wasn't doing it when I first bought it, at least, not to my knowledge as it was plugged in almost every time that I use it. I know that it's not good for the battery... -
Per monitor sleep setting
in Windows 10 Ask InsiderPer monitor sleep setting: Is there a way to configure sleep settings per monitor. One monitor is my actual monitor, the extended 'monitor' is an hdmi cable to my receiver for sound only. When my display goes to sleep, the sound cuts out too (so no Spotify in the background for instance). Would be... -
No sound through monitor speakers after monitor turns off by power plan setting
in Windows 10 Performance & MaintenanceNo sound through monitor speakers after monitor turns off by power plan setting: I had a one monitor setup with power plan setting to turn off monitor after 5 mins of inactivity. The monitor is a Iiyama G-Master Silver Crow GB2730QSU-B1 connected to my GPU via Display port. The sound would be going on to the monitor speakers via DP. GPU is a MSI Geforce... -
Per-monitor sleep settings
in Windows 10 Performance & MaintenancePer-monitor sleep settings: I use an HDMI connection for both a screen and audio, so when the screen goes to sleep I lose sound. Is there a way to configure a particular monitor/HDMI connection to never sleep? I want to keep power saving settings on my display, but not lose sound when it goes to... -
Accidenitly Turned Off Monitor Settings
in Windows 10 CustomizationAccidenitly Turned Off Monitor Settings: I have a Windows 10 laptop with a broken screen. I had been using an external monitor just fine, however, I went into my settings and accidently turned off the external monitor settings. I thought I was turning off the broken, attached monitor, but it turned off my external... -
Power setting turn off Intel speedstep
in Windows 10 SupportPower setting turn off Intel speedstep: Checked my UEFI bios and noted that speedstep is turned off. Can a Windows 10 power setting turn speedstep off in bios? Ver 1803, Dell laptop, >my usage does not stress the laptop<. Task Manager & CPU-z both show 2.5 g for speed HWINFO shows temp as around 45c 112800 -
Monitor turns off after 10min (not screensaver or power settings)
in Windows 10 SupportMonitor turns off after 10min (not screensaver or power settings): Hello just few days ago monitor (Asus PG278Q) started turning off after 10 min while watching media or idle. Checked screensaver: set to 'none' Checked power settings: max performance, set to never shut down or sleep. What else can turn off monitor except screensaver...
