Windows 10: Motherboard power light (PS_SW) is flashing and system wont boot up
Discus and support Motherboard power light (PS_SW) is flashing and system wont boot up in Windows 10 Drivers and Hardware to solve the problem; Yes the missing female pin is correct, just looked at a spare Corsair PSU I have here to check. Another thing I've thought of, might be worth checking... Discussion in 'Windows 10 Drivers and Hardware' started by Zibeltor, Dec 30, 2016.
  1. clam1952 Win User
    Another thing I've thought of, might be worth checking there are no loose screws under the motherboard shorting something out.
    Agreed I'd head to the Hardware section for some of the extremely good advice given there.
    clam1952, Jan 1, 2017
    #16
  2. Steve C Win User
    I have the same motherboard. I once had a flashing on board power LED due to a faulty XFX PSU which could not provide a reliable +5V standby signal. Test the PSU in isolation using the paper clip test and measure whether the PSU can provide a steady +5V standby signal. See How to Check a Power Supply: 12 Steps (with Pictures) - wikiHow
    Steve C, Jan 2, 2017
    #17
  3. Zibeltor Win User
    clam1952; not a bad idea! I unscrewed the motherboard and checked it out--didn't see any loose or out-of-place pieces.
    Steve C; Awesome! Thank you for the tip! I will try that when I get home! Edit: I tried it--the fan was almost too quiet to hear, but I noticed a click and also some moving air coming out the back. I doubted my PSU was the problem (it's fairly new), but I'm glad to have it relatively confirmed. Although that article you linked says I would need a voltmeter to really be sure...
    While I got y'all here... can someone confirm for me that an LGA 1151 socket motherboard (like the replacement board I'm considering: a Gigabyte Z170x-UD3 Ultra) is compatible with an LGA 1150 CPU (like the replacement i7-4790k I want to get)? That motherboard/CPU compatibility issue feels so needlessly complicated...
    Zibeltor, Jan 2, 2017
    #18
  4. Berton Win User
    i7 4770k LGA 1150 vs LGA 1151 - [Solved] - Components
    Seems they don't interchange. That pretty much been the way since some of the early Intel Pentium boards that couldn't accept AMD CPUs. It was possible in the 80386 and 80486 days to use a board for either CPU but there were numerous jumpers needing setting depending upon which CPU was used.
    Berton, Jan 2, 2017
    #19
  5. Zibeltor Win User
    Thank you so much, Berton! I found some conflicting/ambiguous stuff about it and am so glad I double-checked: saved me a lot of time and money. I had hoped it had opened up a bit, but I'll now know to stick to specific socket types.
    Zibeltor, Apr 5, 2018
    #20
  1. Motherboard power light (PS_SW) is flashing and system wont boot up - Similar Threads - Motherboard power light
  2. pc wont boot, cpu flashes red then powers down
    pc wont boot, cpu flashes red then powers down: H100i progigabyte RTX 2070 superi9 9900Kseasonic Focus GX 550Asus Prime Z390-Pwas working fine, but now the cpu flashes red and fans spin, then it goes off, and repeats itself.any help please?thanks...
  3. pc wont boot, cpu flashes red then powers down
  4. pc wont boot, cpu flashes red then powers down
  5. Hp laptop wont turn on, long flashing power light.
    Hp laptop wont turn on, long flashing power light.: Had the computer for a year. Than after the warranty expired, the computer wouldn't turn on. Upon pressing the power button, I get no display, from the screen or hdmi output. But, power indicator and charger indicator light flashes for 8 seconds and turns off, repeatedly....
  6. Hp laptop wont turn on, long flashing power light.
  7. Keyboard light wont light up when booted to windows
    Keyboard light wont light up when booted to windows: Hello there I'm really need help here the problem as follows:recently updated to windows 11 then I realize the keyboard light not working anymorethe light only works on boot startup bios setting, the light turned off when entering the windows logon screen can I know why this...
  8. Keyboard light wont light up when booted to windows
  9. PC Not Booting DRAM Flashing on Motherboard
    PC Not Booting DRAM Flashing on Motherboard: A couple of days ago I performed a scan and clean on my computer with the software I had downloaded. I had used it multiple times with no issues just to make sure all of my drivers were updated and there were no useless files on my computer to keep more free storage. The...
  10. Power light on but no boot
    Power light on but no boot: This has gone from bad to worse. It started with an error message when I went to close down, to the effect that the Start Button wasn't working and would reset on restart. I restarted; it didn't reset. I could use programs but the Start button still wouldn't work. I tried to...
