Windows 10: MS Edge and PDF printer problems
Discus and support MS Edge and PDF printer problems in Windows 10 Drivers and Hardware to solve the problem; Hi, I'm able to print from Excel, Work and Powerpoint on my new Lenovo Yoga laptop to my Brother multi-function printer but whenever I try to print... Discussion in 'Windows 10 Drivers and Hardware' started by Thomai01, Jun 3, 2019.
MS Edge and PDF printer problems - Similar Threads - Edge PDF printer
MS Print to PDF no longer a printer option
in Windows 10 GamingMS Print to PDF no longer a printer option: Microsoft Print to PDF is no longer an option when I try to print on my laptop. It is selected turned on in settings, but still doesn't exist in the printer options. If I try to install it manually, it is not available as an option for installation. I've tried to find a... -
in Windows 10 Software and AppsMS Print to PDF no longer a printer option: Microsoft Print to PDF is no longer an option when I try to print on my laptop. It is selected turned on in settings, but still doesn't exist in the printer options. If I try to install it manually, it is not available as an option for installation. I've tried to find a... -
Adobe *.pdf files open in MS Edge
in Windows 10 GamingAdobe *.pdf files open in MS Edge: How can I spot Adobe *.pdf files from opening in MS Edge? I have Adobe Acrobat installed but the default keeps changing back to MS Edge. Can this be fixed? Thanks.... -
in Windows 10 Software and AppsAdobe *.pdf files open in MS Edge: How can I spot Adobe *.pdf files from opening in MS Edge? I have Adobe Acrobat installed but the default keeps changing back to MS Edge. Can this be fixed? Thanks.... -
Tabs problem with MS Edge
in Browsers and EmailTabs problem with MS Edge: I am annoyed by something Edge does every time I open it. Suppose I visit BBC London, Paris Match, Settings, etc. and then close down Edge. The next time I open Edge, at the very top of the page, I get tabs showing BBC London, Paris Match, Settings, etc. Sometimes there are... -
Microsoft Edge print to pdf problem
in Browsers and EmailMicrosoft Edge print to pdf problem: I need to save some webpages to pdf. I tried a Firefox extension Save as PDF, but that adds the company name to every page (fair enough - it's freeware). So I tried Microsoft Edge print to pdf function. Works OK, but for some reason, Edge adds a watermark of sorts 'Skip... -
MS Edge and PDF files - High-jacked
in Windows 10 CustomizationMS Edge and PDF files - High-jacked: What has happened with my Adobe Acrobat XI and MS Edge. Whenever I want create or open a PDF file, MS Edge takes over and displays the file. This is a recent occurrence, but it persists. Even though Acrobat asks me to make it my default for PDF files, which I do, Edge is... -
Microsoft Edge PDF file problems
in Browsers and EmailMicrosoft Edge PDF file problems: Typical MS I typed this message in and MS decided I was not logged in - so I logged in and lost the message - had to type it all again! Warning to you all - make a copy of your message before you submit your message. Microsoft Edge (MSE) is MS new offering in Windows 10... -
MS Edge narrating e-books but not pdf
in Browsers and EmailMS Edge narrating e-books but not pdf: Hello, I own a win10 home laptop, and wile exploring Edge, I realized it has a text-to-speech feature. I opened an .epub file and on top right a small button appears among others that enables narrating mode. It work surprisingly well, I experimented with a variety of voices...
MS edge print to Acrobat PDF problems
