Windows 10: multi channel sound not selectable in sound panel
Discus and support multi channel sound not selectable in sound panel in Windows 10 Customization to solve the problem; An audio/video receiver is connected to the PC via HDMI. Speakers options for 5.1 and 7.1 are greyed (not selectable), do you know how to make them... Discussion in 'Windows 10 Customization' started by BlaiseHaguinet, Jan 28, 2019.
multi channel sound not selectable in sound panel - Similar Threads - multi channel sound
Help with the sounds panel
in Windows 10 GamingHelp with the sounds panel: when I try to change windows sound in the sounds panel > "Sounds" Tab there is no way i can change the sounds,It seems like the sound panel window is not fully open... -
in Windows 10 Software and AppsHelp with the sounds panel: when I try to change windows sound in the sounds panel > "Sounds" Tab there is no way i can change the sounds,It seems like the sound panel window is not fully open... -
in Windows 10 CustomizationHelp with the sounds panel: when I try to change windows sound in the sounds panel > "Sounds" Tab there is no way i can change the sounds,It seems like the sound panel window is not fully open... -
Sound Panel Popup
in Windows 10 CustomizationSound Panel Popup: That panel is popping up out of nowhere and cannot be dismissed. Any ideas? [ATTACH] https://answers.microsoft.com/en-us/windows/forum/all/sound-panel-popup/868041dd-6a5e-4dbf-baa0-3f6cdfa7bd12 -
Sound Control Panel
in Windows 10 CustomizationSound Control Panel: Ever since the new windows updates, Sound Control Panel , also known in the bottom right (from sounds - speaker) as Playback Devices / Recording Devices, this tab has been taken out and we were given some option not many care about (even if they do, a lot of people never... -
Control Panel Sounds
in Windows 10 CustomizationControl Panel Sounds: Device Disconnect makes a sound while computer is in sleep mode. How do I turn it off? https://answers.microsoft.com/en-us/windows/forum/all/control-panel-sounds/4c65c3d3-48e9-43c9-8531-bb29344b98a1 -
Sound channels on windows 10
in Windows 10 Drivers and HardwareSound channels on windows 10: I would like to know if i can send out different program sounds on different channels. For example i want to connect my pc to a mixer then i can change the volume of each program on my mixer but to do that i need to output every progtam on different channel so i can plug them... -
Sound Control Panel
in Windows 10 Drivers and HardwareSound Control Panel: Hi.Running a Windows 10 computer.Running headless using Remote Desktop.Only use the computer as a music server.Have a dac connected to computer.In sound panel under playback it's only option is Remote Audio.Dac and other options are not there.Right click to show disabled and... -
No sound, No Control Panel
in Windows 10 SupportNo sound, No Control Panel: Installed Win10 and have the following problems. 1) I have no sound; Sound icon on task bars says "No audio Output Device Installed." When I run troubleshooter, it says Troubleshooting couldn't detect the problem. 2) Control Panel: When I click on control panel it...
