Windows 10: Multi monitor wallpaper problem...
Discus and support Multi monitor wallpaper problem... in Windows 10 Customization to solve the problem; How do I stop my wallpapers from moving about when I turn off one of my three monitors? This is very annoying. I have 3 monitors... two for... Discussion in 'Windows 10 Customization' started by teachermark, Jan 10, 2016.
Multi monitor wallpaper problem... - Similar Threads - Multi monitor wallpaper
Multi-Monitors, wallpapers reset after monitors sleep
in Windows 10 GamingMulti-Monitors, wallpapers reset after monitors sleep: Title says it all. I just recently picked up three matching monitors Acer XF234Y, all connected via DisplayPort to an RTX 3070.Previously I had three different model monitors, two connected via DP and one via HDMI and I never had an issue with this. All of the hardware... -
in Windows 10 Software and AppsMulti-Monitors, wallpapers reset after monitors sleep: Title says it all. I just recently picked up three matching monitors Acer XF234Y, all connected via DisplayPort to an RTX 3070.Previously I had three different model monitors, two connected via DP and one via HDMI and I never had an issue with this. All of the hardware... -
Multi Monitor Wallpaper Problem
in Windows 10 GamingMulti Monitor Wallpaper Problem: so i try to right click to set a certain image to a certain monitor but on shows monitor 2 . if i change a setting in windows for display then it will show option for monitor one and monitor 2... -
in Windows 10 Software and AppsMulti Monitor Wallpaper Problem: so i try to right click to set a certain image to a certain monitor but on shows monitor 2 . if i change a setting in windows for display then it will show option for monitor one and monitor 2... -
in Windows 10 CustomizationMulti Monitor Wallpaper Problem: so i try to right click to set a certain image to a certain monitor but on shows monitor 2 . if i change a setting in windows for display then it will show option for monitor one and monitor 2... -
Multi-Monitor Wallpaper Malfunctions on Boot
in Windows 10 CustomizationMulti-Monitor Wallpaper Malfunctions on Boot: I have recently upgraded my CPU, Motherboard and boot device.For the past few weeks I've been having an issue with my wallpaper.What I want is an image to span across both my monitors, but every time I boot into my machine it repeats what is shown on the main monitor instead... -
Multi Monitor Custom Wallpaper Randomly Disappears
in Windows 10 CustomizationMulti Monitor Custom Wallpaper Randomly Disappears: Been having this issue for a couple of weeks now, where out of nowhere, one of my four monitor's background custom image will "disappear", and the monitor will be black. If I hit refresh, the image sometimes comes back, but one or more of the other monitors' backgrounds will... -
Multi-Monitor Wallpaper control
in Windows 10 CustomizationMulti-Monitor Wallpaper control: I currently have a triple monitor set up, with two vertical monitors and a horizontal monitor, I want to be able to use slideshow wallpapers for these monitors and use two different folders for the different orientations of monitor. I.E. a slideshow for the horizontal... -
W10 Anniversary Multi-Monitor Wallpaper Issues
in Windows 10 CustomizationW10 Anniversary Multi-Monitor Wallpaper Issues: I've lost the ability to specifically assign wallpapers throughout my three monitors after the Windows 10 Anniversary Update. When rt clicking, the options for specific monitor assignments show up in triplicate. [img] The menu in the past would include "...Set for...
