Windows 10: my audio sound is not working plz help me in that
Discus and support my audio sound is not working plz help me in that in Windows 10 Gaming to solve the problem; I am trying to figure out the solution of my audio but its not working i dont know whats going on... Discussion in 'Windows 10 Gaming' started by M.Bilal Shakeel, Sep 27, 2022.
  1. my audio sound is not working plz help me in that
  2. Audio not working! Need Help!!
    I understand your concerned. Let me help you to fix the issue.
    Let’s try simple troubleshooting steps and check if this helps in resolving the issue. Follow the below methods.
    Method 1.
    I would suggest you to run sound audio troubleshooter, it will automatically detect the problem and fix it. Follow the below steps.
    • Press Windows key + R and click on
      Control Panel
    • Click on View by: category and click on
      Small icon.
    • Now click on troubleshooting and click on
      Hardware and Sound.
    • Click on Playing Audio and Click on Next button.
    Method 2.
    Step 1.
    I suggest you to uninstall/reinstall the sound adapter driver and check.
    • Press Windows key + X and select
      Device manager
    • Now click on Sound, video and game controllers
      to expand, right click on the device and click on uninstall.
    • Once you are done installing the driver, restart the computer. It will automatically install the sound adapter driver.
    If the still persist, try the below steps.
    Step 2.
    I suggest you to update the audio driver and check.
      Device manager
    • Now click on Sound, video and game controllers and right click on it and
      update the software.
    If the above methods did not help to fix the issue, try the below method.
    Method 3.
    I suggest you to go to the below link, select appropriate Windows operating system and download the audio driver and install same.
    http://www.asus.com/support/Download/3/580/0/5/0gOdr7OTSYtNTbh2/45/
    Hope this helps. Let us know the result.
    Billion Debbarma, Sep 27, 2022
  3. Sound problem
    • Click Hardware and Sound.
    Radney Dri, Sep 27, 2022
  4. my audio sound is not working plz help me in that
    My sound will not work, Help Please
    To assist you better, I would like to know that; is the issue occur only when trying to play sounds through website/internet?
    I suggest you to try running audio troubleshooter and check if it helps.
    Follow the below steps:
    • Type Troubleshooting in the Search area on the taskbar and select
      Troubleshooting.
    • Select Hardware and Sound.
      Sound
      and follow the on screen.
    Santosh_Rai, Sep 27, 2022
  1. my audio sound is not working plz help me in that - Similar Threads - audio sound working
  2. HELP ME PLZ
    HELP ME PLZ: Everytime i put windows 11 on my pc , something is going wrong everything is lagging and my pc crashes but i am on windows 10 now and always telling me to go win 11 but now that i am in win 10 i am not lagging anymore! Can you help me why my pc lags? I have gtx 1660ti 6 gb ,...
  3. HELP ME PLZ
  4. HELP ME PLZ
  5. Plz help me
    Plz help me: Plz help me I got this new laptop this HP 450 G2 15.6" LAPTOP INTEL i3 500GB STORAGE 8GB RAM WEBCAM WINDOWS 11 856 and I forgot my windows password https://answers.microsoft.com/en-us/windows/forum/all/plz-help-me/71813216-d38a-467e-b894-edd0ca26db2c
  6. my audio sound is not working plz help me in that
    my audio sound is not working plz help me in that: I am trying to figure out the solution of my audio but its not working i dont know whats going on https://answers.microsoft.com/en-us/windows/forum/all/my-audio-sound-is-not-working-plz-help-me-in-that/88096808-0a94-4eb1-81f0-17bf3f4cdec6
  7. plz help me
    plz help me: : fifa4zf.exe, : 1.0.0.0, : 0x602e0a75 : ntdll.dll, : 10.0.19041.804, : 0x4544b4a1 : 0xc0000374 : 0x00000000000ff099 ID: 0x1e14 : 0x01d70e7e34ab3998 : D:\FIFA ONLINE 4\EA SPORTSTM FIFA ONLINE 4\fifa4zf.exe : C:\WINDOWS\SYSTEM32\ntdll.dll ID:...
  8. Help me plz
    Help me plz: i had been messing with my background and randomly my taskbar picture things got like big and wide as you can see in the picture submitted by /u/GrapeMan8 [link] [comments] https://www.reddit.com/r/Windows10/comments/imxznr/help_me_plz/
  9. Help me plz
    Help me plz: why are my drivers and adapter's all different from this brand new hp stream book..i have never downloaded anything yet there is a list of driver and adapter and device's..also there was only 1 user listed not even 'guest', as I deleted it..now apparently there are numerous...
  10. HELP ME PLZ!!!!!!!!
    HELP ME PLZ!!!!!!!!: I own a notebook PC with windows 10, and for some reason will turn off on its own. While turning off, the screen will turn red then black. I know for sure that my power plan settings are fine and I did the Troubleboot for Blue Screen (I think that's what its called) so if u...
