Windows 10: My audio/sound stopped working randomly. Help.
Discus and support My audio/sound stopped working randomly. Help. in Windows 10 BSOD Crashes and Debugging to solve the problem; I was using my computer normally and out of no where the audio/sound stops working randomly. I have tried re-installing audio drivers but my... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Afshin Haksar, Aug 16, 2022.
My audio/sound stopped working randomly. Help. - Similar Threads - audio sound stopped
in Windows 10 Software and AppsMy audio/sound stopped working randomly. Help.: I was using my computer normally and out of no where the audio/sound stops working randomly. I have tried re-installing audio drivers but my manufacturer Dell only gives drivers of my PC till windows 8, and i have windows 10.I ran the trouble-shooter, re-installed my graphics... -
in Windows 10 GamingMy audio/sound stopped working randomly. Help.: I was using my computer normally and out of no where the audio/sound stops working randomly. I have tried re-installing audio drivers but my manufacturer Dell only gives drivers of my PC till windows 8, and i have windows 10.I ran the trouble-shooter, re-installed my graphics... -
Sound stops working randomly
in Windows 10 Software and AppsSound stops working randomly: Hi there,My sounds randomly stops working, i have a Beyerdynamic DT990 250 Ohm hooked op to a SoundblasterX G6. I also use wave link software to controll all the different sound inputs/outputs i have. The only fix i currently have to get my sound back, is to either restart my... -
in Windows 10 CustomizationSound stops working randomly: Hi there,My sounds randomly stops working, i have a Beyerdynamic DT990 250 Ohm hooked op to a SoundblasterX G6. I also use wave link software to controll all the different sound inputs/outputs i have. The only fix i currently have to get my sound back, is to either restart my... -
in Windows 10 GamingSound stops working randomly: Hi there,My sounds randomly stops working, i have a Beyerdynamic DT990 250 Ohm hooked op to a SoundblasterX G6. I also use wave link software to controll all the different sound inputs/outputs i have. The only fix i currently have to get my sound back, is to either restart my... -
in Windows 10 Drivers and HardwareSound stops working randomly: So I've gone through just about every single option I've found through google. I just built a brand new PC everything was working fine the first day of use. I turned it on today and the sound wasn't working. I went through everything and finally turned to uninstalling the... -
Audio randomly stopped working
in Windows 10 Ask InsiderAudio randomly stopped working: Yesterday, I was on my MSI laptop watching some Netflix. I left it for 30 min and when I came back it was on sleep mode (as it should). When I woke my laptop up and went back to the Netflix tab, the audio did not work. I unplugged my headphones and the audio still did not... -
Sound randomly stopped working
in Windows 10 Ask InsiderSound randomly stopped working: Hi, I have a Windows 10 Desktop. Everything was running fine. I was browsing reddit on one monitor and playing youtube in the other like usual. I paused youtube to go the store. When I came back 30 minutes later and resumed video the sound would not work. I have 3 different... -
audio randomly stops working
in Windows 10 Drivers and Hardwareaudio randomly stops working: Hello all, My computer is currently connected to my Vizio E420-A0 TV (HDMI). My audio randomly stops working and the display audio device disappears. When it works I can see it in device manager: [img] [img] And when it stops working it disappears: [img]...
