Windows 10: my monitor wired problem.
Discus and support my monitor wired problem. in Windows 10 Software and Apps to solve the problem; helloI have a problem that I cannot fixthe problem is that when I turn the computer the monitor doesn't detect my pcbut when windows boot up it detect... Discussion in 'Windows 10 Software and Apps' started by XZ_MOHAMMED, Sep 28, 2022.
my monitor wired problem. - Similar Threads - monitor wired problem
I use a wired monitor with my laptop but now i cannot close the lid because my wired...
in Windows 10 GamingI use a wired monitor with my laptop but now i cannot close the lid because my wired...: A the beginning everything was working all fine but then i started tweaking some display options and suddenly on time i tried closing my laptops lid and my monitr screen will just black with the message i said before. I have tried many solutions such as choosing another... -
in Windows 10 Software and AppsI use a wired monitor with my laptop but now i cannot close the lid because my wired...: A the beginning everything was working all fine but then i started tweaking some display options and suddenly on time i tried closing my laptops lid and my monitr screen will just black with the message i said before. I have tried many solutions such as choosing another... -
in Windows 10 Gamingmy monitor wired problem.: helloI have a problem that I cannot fixthe problem is that when I turn the computer the monitor doesn't detect my pcbut when windows boot up it detect itthis means if I need to go to bios sitting I can't because windows didn't boot yethelp me please.... -
in Windows 10 Drivers and Hardwaremy monitor wired problem.: helloI have a problem that I cannot fixthe problem is that when I turn the computer the monitor doesn't detect my pcbut when windows boot up it detect itthis means if I need to go to bios sitting I can't because windows didn't boot yethelp me please.... -
wired second monitor
in Windows 10 Gamingwired second monitor: I can't figure out how to get my laptop to be used as a second monitor for my pc. I think my laptop could do the task of second screen since it has a normal HDMI port but it won't detect any monitors in the display settings, I have looked at every article possible with no... -
in Windows 10 Software and Appswired second monitor: I can't figure out how to get my laptop to be used as a second monitor for my pc. I think my laptop could do the task of second screen since it has a normal HDMI port but it won't detect any monitors in the display settings, I have looked at every article possible with no... -
Problem with Bluetooth and wired mics
in Windows 10 GamingProblem with Bluetooth and wired mics: I'm running Windows 10 on a brand new computer and having a problem getting any mics working on my computer. I have tried Bluetooth and just to plug a headset directly into my front and rear panel.Plugged in:When I plug a mic in, it's detected. You can see it... -
MULTIPLE WIRED MONITOR TROUBLE CONNECTING
in Windows 10 Drivers and HardwareMULTIPLE WIRED MONITOR TROUBLE CONNECTING: TRYING TO CONNECT MY hp 21kd TO my hp laptop with a wire I go to start >settings>system>display then the only option is search for a wireless monitor which it never finds help please... -
Wired connection problem
in Windows 10 Network and SharingWired connection problem: I upgraded to version 2004 and it disabled all of our networking we have three wired computers all running windows 10 and a couple of laptops also running windows 10. I ended up reinstalling windows to the previous version because I could not get it to work with any...
