Windows 10: my monitor wired problem.
Discus and support my monitor wired problem. in Windows 10 Gaming to solve the problem; helloI have a problem that I cannot fixthe problem is that when I turn the computer the monitor doesn't detect my pcbut when windows boot up it detect... Discussion in 'Windows 10 Gaming' started by XZ_MOHAMMED, Sep 28, 2022.
  1. my monitor wired problem.
    helloI have a problem that I cannot fixthe problem is that when I turn the computer the monitor doesn't detect my pcbut when windows boot up it detect itthis means if I need to go to bios sitting I can't because windows didn't boot yethelp me please.
  2. i have a problem to connect 2 monitors.
    Hi Ron,
    • What changes did you make in the BIOS? As making the changes in the BIOS is only recommended by Microsoft if done by the manufacturer.
    • How are you connecting to the 2nd monitor?
    I suggest you to follow the steps from this article below:
    Windows help & learning
    [Applies to Windows 10 as well]
    Regards.
    SujataMoktan, Sep 28, 2022
  3. Sasqui Win User
    Overclocking / Undervolting guide for Vega 56 or 64?
    Here's a quick laundry list:
    List of software to use for overclocking and testing
    Examples:
    Wattman (and how to find and use it, like an overview, including profiles)
    Unigine Valley or Heaven (use this for quick testing while changing settings in Wattman and checking for stability / artifacts) ...just suggesting this
    How to monitor cores / mem speeds and temps during testing (I've seen screen overlays, and others using GPUz)
    Step-by step overclocking in Wattman
    Fan speeds
    Power limit
    Temp limit
    Voltages
    Core speeds
    Memory speeds
    Sasqui, Sep 28, 2022
  4. my monitor wired problem.
    Trouble with 2 monitors
    Hi Tim,
    I suggest you to change the settings to Extended Monitor and check if it helps.
    Please follow below steps:
    • Right Click any ware of the Desktop, and launch Personalization.
    • Go to dual monitor settings under personalization, and change it Extended Monitor.
    Please get back to us for future support, we’ll be glad to assist you further.
    Prabhavathi Patil, Sep 28, 2022
  1. my monitor wired problem. - Similar Threads - monitor wired problem
  2. I use a wired monitor with my laptop but now i cannot close the lid because my wired...
    I use a wired monitor with my laptop but now i cannot close the lid because my wired...: A the beginning everything was working all fine but then i started tweaking some display options and suddenly on time i tried closing my laptops lid and my monitr screen will just black with the message i said before. I have tried many solutions such as choosing another...
  3. I use a wired monitor with my laptop but now i cannot close the lid because my wired...
    my monitor wired problem.: helloI have a problem that I cannot fixthe problem is that when I turn the computer the monitor doesn't detect my pcbut when windows boot up it detect itthis means if I need to go to bios sitting I can't because windows didn't boot yethelp me please....
  5. my monitor wired problem.
  6. wired second monitor
    wired second monitor: I can't figure out how to get my laptop to be used as a second monitor for my pc. I think my laptop could do the task of second screen since it has a normal HDMI port but it won't detect any monitors in the display settings, I have looked at every article possible with no...
  7. wired second monitor
  8. Problem with Bluetooth and wired mics
    Problem with Bluetooth and wired mics: I'm running Windows 10 on a brand new computer and having a problem getting any mics working on my computer. I have tried Bluetooth and just to plug a headset directly into my front and rear panel.Plugged in:When I plug a mic in, it's detected. You can see it...
  9. MULTIPLE WIRED MONITOR TROUBLE CONNECTING
    MULTIPLE WIRED MONITOR TROUBLE CONNECTING: TRYING TO CONNECT MY hp 21kd TO my hp laptop with a wire I go to start >settings>system>display then the only option is search for a wireless monitor which it never finds help please...
  10. Wired connection problem
    Wired connection problem: I upgraded to version 2004 and it disabled all of our networking we have three wired computers all running windows 10 and a couple of laptops also running windows 10. I ended up reinstalling windows to the previous version because I could not get it to work with any...
