Windows 10: My Phone App does not work properly - White noise on call instead of audio. How can I fix it?
Discus and support My Phone App does not work properly - White noise on call instead of audio. How can I fix it? in Windows 10 Software and Apps to solve the problem; Hi!I got a problem that my Sony Xperia XA2 now makes white noise incall but was working fine before when connected. When I pick calls on the mobile... Discussion in 'Windows 10 Software and Apps' started by Lilia Cone, Jul 1, 2021.
My Phone App does not work properly - White noise on call instead of audio. How can I fix it? - Similar Threads - Phone App does
Phone Link does not make calls. How can I fix this?
in Windows 10 Software and AppsPhone Link does not make calls. How can I fix this?: I have a BARROT Bluetooth Adapter. Windows Phone Link does not do calls, saying I need Bluetooth on my PC. Under device manager there is a Question mark under Bluetooth Peripheral Device and SMS/MMS. here are no drivers installed. The device IDs are... -
in Windows 10 GamingPhone Link does not make calls. How can I fix this?: I have a BARROT Bluetooth Adapter. Windows Phone Link does not do calls, saying I need Bluetooth on my PC. Under device manager there is a Question mark under Bluetooth Peripheral Device and SMS/MMS. here are no drivers installed. The device IDs are... -
how can i fix my microphone making buzzing sounds/white noise?
in Windows 10 Gaminghow can i fix my microphone making buzzing sounds/white noise?: Hello! i have found myself hearing strange buzzing/white noise from my microphone instead of my voice, it happened the first time for a brief moment before it stopped, the second time it took longer and i had updated all my drivers to see if it would help, however, it... -
in Windows 10 Software and Appshow can i fix my microphone making buzzing sounds/white noise?: Hello! i have found myself hearing strange buzzing/white noise from my microphone instead of my voice, it happened the first time for a brief moment before it stopped, the second time it took longer and i had updated all my drivers to see if it would help, however, it... -
in Windows 10 Drivers and Hardwarehow can i fix my microphone making buzzing sounds/white noise?: Hello! i have found myself hearing strange buzzing/white noise from my microphone instead of my voice, it happened the first time for a brief moment before it stopped, the second time it took longer and i had updated all my drivers to see if it would help, however, it... -
Help: Cracking noises instead of audio
in Windows 10 Ask InsiderHelp: Cracking noises instead of audio: Hi there, I really don't know what happened, I just left my laptop (Windows 10, Acer) alone for like 10min and when I got back, now it does not output/play any audio anymore but instead a weird cracking noise and with head phones just white noise.. I don't know what happend,... -
Static/Background noise during phone call using Your Phone app
in Windows 10 Ask InsiderStatic/Background noise during phone call using Your Phone app: As the title says, there's a bunch of static when doing that, even though I have a dedicated headset with mic which rarely if ever gives static when using video conferencing and such from my PC. My question is, how do I stop this, or failing that, is it possible to change the... -
Audio Problems-White noise in the background...
in Windows 10 Drivers and HardwareAudio Problems-White noise in the background...: Every time I run an app that requires audio, I keep getting this constant white noise playing at the same time. I've done all the tests, updates, and system restore a couple of times and nothing works. Is there a ay for a tech to fix this online while I watch? Thank you.... -
Windows 10 Audio White Noise
in Windows 10 BSOD Crashes and DebuggingWindows 10 Audio White Noise: The sound on my laptop recently stopped working entirely. The sound has been completely replaced by faint white noise that plays slightly after the sound should start and lingers slightly after it should stop. Additionally, when switching to wired headphones the audio always...
