Windows 10: My power toggle is greyed out and there is no battery icon.
Discus and support My power toggle is greyed out and there is no battery icon. in Windows 10 Software and Apps to solve the problem; I got this secondhand Microsoft computer and it's never had the battery icon. I went onto taskbar and found that the power toggle is on but is greyed... Discussion in 'Windows 10 Software and Apps' started by Alex :, Jan 2, 2023.
My power toggle is greyed out and there is no battery icon. - Similar Threads - power toggle greyed
in Windows 10 GamingMy power toggle is greyed out and there is no battery icon.: I got this secondhand Microsoft computer and it's never had the battery icon. I went onto taskbar and found that the power toggle is on but is greyed out. I have fixed corrupt files but that did nothing. There is also nothing on the device manager to do with batteries either.... -
in Windows 10 CustomizationMy power toggle is greyed out and there is no battery icon.: I got this secondhand Microsoft computer and it's never had the battery icon. I went onto taskbar and found that the power toggle is on but is greyed out. I have fixed corrupt files but that did nothing. There is also nothing on the device manager to do with batteries either.... -
Battery icon is greyed out
in Windows 10 GamingBattery icon is greyed out: I want to see my battery icon to keep on trackm but after some time it will go out and if I check the settings it is greyed out. How to fix this? https://answers.microsoft.com/en-us/windows/forum/all/battery-icon-is-greyed-out/9481ac50-05a4-4cdf-9e5e-430d2967ed75 -
in Windows 10 Software and AppsBattery icon is greyed out: I want to see my battery icon to keep on trackm but after some time it will go out and if I check the settings it is greyed out. How to fix this? https://answers.microsoft.com/en-us/windows/forum/all/battery-icon-is-greyed-out/9481ac50-05a4-4cdf-9e5e-430d2967ed75 -
battery icon greyed out!
in Windows 10 Gamingbattery icon greyed out!: I want the battery icon active in my task bar but it always disappear once in a while and comeback. I tried checking settings to make sure it is on, but it is already on. Everytime it went missing, and I check the settings, it will no longer available and greyed out. How to... -
power icon toggle is greyed out
in Windows 10 Gamingpower icon toggle is greyed out: I checked my battery icon and it's showing off. When I check on the settings to turn it on, the toggle is greyed out and cannot turn it back on. Restarting will fix it, but will happen again eventually. I need permanent fix. Thankyou.... -
in Windows 10 Software and Appspower icon toggle is greyed out: I checked my battery icon and it's showing off. When I check on the settings to turn it on, the toggle is greyed out and cannot turn it back on. Restarting will fix it, but will happen again eventually. I need permanent fix. Thankyou.... -
in Windows 10 Customizationpower icon toggle is greyed out: I checked my battery icon and it's showing off. When I check on the settings to turn it on, the toggle is greyed out and cannot turn it back on. Restarting will fix it, but will happen again eventually. I need permanent fix. Thankyou.... -
Greyed out battery icon
in Windows 10 CustomizationGreyed out battery icon: I want the battery icon active in the taskbar but it always disappear once in a while. I go to setting and try to turned it on, but it is already on. But when the icon is missing it will turned grey and no longer accessible. What to do?...
