Windows 10: My shift and my 0,9,8,7 are not working and sometimes they work and not and i have to use...
Discus and support My shift and my 0,9,8,7 are not working and sometimes they work and not and i have to use... in Windows 10 Customization to solve the problem; Hi guys so my shift and 0,9,8,7 is not working so I need help plz help me fix it... Discussion in 'Windows 10 Customization' started by DanialButt1, Jan 21, 2020.
My shift and my 0,9,8,7 are not working and sometimes they work and not and i have to use... - Similar Threads - shift are working
Shift keys, 7, 8 ,9, 0 keys and arrows keys have late responsed/unresponive
in Windows 10 GamingShift keys, 7, 8 ,9, 0 keys and arrows keys have late responsed/unresponive: Hi, I have a Windows 11 pro model Surface laptop 4. Some of the keys on my physical keyboard not the kind of keyboards you need to pair with a dongle or bluetooth, no, it's the physical keyboard. These keys currently are the shift key, 7, 8, 9, 0 keys and the left, right and... -
in Windows 10 Software and AppsShift keys, 7, 8 ,9, 0 keys and arrows keys have late responsed/unresponive: Hi, I have a Windows 11 pro model Surface laptop 4. Some of the keys on my physical keyboard not the kind of keyboards you need to pair with a dongle or bluetooth, no, it's the physical keyboard. These keys currently are the shift key, 7, 8, 9, 0 keys and the left, right and... -
Both the shift keys not working sometimes
in Windows 10 GamingBoth the shift keys not working sometimes: Product: HP Laptop Operating System: Microsoft Windows 11I've had this laptop for just under 3 years and both shift keys have been malfunctioning for a while now, entire keyboard works normally but those 2 sometimes just stop working for hours. I've tried checking, updating... -
ctrl+shift+0 not working
in Windows 10 Gamingctrl+shift+0 not working: backstory: hi, so i've been trying to set up a button on a drawing tablet wacom intuos s ctl-4100 to switch between brush and eraser tools in an art program paint.net. to do so, i've found a program eraser brush eyedropper hotkey by ugochi creative that uses ctrl+shift+0 as a... -
in Windows 10 Software and Appsctrl+shift+0 not working: backstory: hi, so i've been trying to set up a button on a drawing tablet wacom intuos s ctl-4100 to switch between brush and eraser tools in an art program paint.net. to do so, i've found a program eraser brush eyedropper hotkey by ugochi creative that uses ctrl+shift+0 as a... -
in Windows 10 Customizationctrl+shift+0 not working: backstory: hi, so i've been trying to set up a button on a drawing tablet wacom intuos s ctl-4100 to switch between brush and eraser tools in an art program paint.net. to do so, i've found a program eraser brush eyedropper hotkey by ugochi creative that uses ctrl+shift+0 as a... -
Shift + 0 not working
in Windows 10 GamingShift + 0 not working: Hi !Suddenly My Shift + 0 combination stopped working .Shift + 9 works ,0 works ,Shift + 0 doesn`t .I have tried to stop all apps bcs I suggested that any of them can use a hotkey shift + 0 , but I have closed everything and I have no effect .Drivers are up-to-date .Is there... -
in Windows 10 Software and AppsShift + 0 not working: Hi !Suddenly My Shift + 0 combination stopped working .Shift + 9 works ,0 works ,Shift + 0 doesn`t .I have tried to stop all apps bcs I suggested that any of them can use a hotkey shift + 0 , but I have closed everything and I have no effect .Drivers are up-to-date .Is there... -
Working on updates at 0% for 9 hours
in Windows 10 Installation and UpgradeWorking on updates at 0% for 9 hours: Hello people, I'm trying to update Windows 10 from 1809 to 1903. The downloading phase was quick, installation took well over 7 hours and now I'm at the restarting stage. The blue screen says working on updates 0% for 9hours. I was wondering whether these astronomical...
