Windows 10: My system says "audio output device not installed"
Discus and support My system says "audio output device not installed" in Windows 10 Gaming to solve the problem; My Asus laptop suddenly decided that my sound output or input was absent. it's not... Discussion in 'Windows 10 Gaming' started by Frank Miles, Apr 30, 2025.
  1. My system says "audio output device not installed"
  2. JohnMilks Win User
    no audio output device installed
    I've tried every step that was suggested, still getting no audio output device installed.
    JohnMilks, Apr 30, 2025
  3. No Audio Output Device is Installed
    You will need to select Windows 8 from the drop down list while installing the driver in compatibility mode.
    I would suggest you to try setting the speaker as default audio output by following the steps below and check if it helps.
    1. Right click on the sound icon on the right bottom corner of the taskbar.
    2. Select "playback devices".
    3. If "speaker" is not set as the default device, highlight it and click "set as default".
    5. Save the changes.
    Let us know the result.
    Wungraileng Vashi, Apr 30, 2025
  4. floare... Win User
    No Audio Output Devices in installed
    I know this has been widely discussed and
    Carlo TJ Independent Advisor (Redirecting ), Replied on July 1, 2021 on
    No Audio Output device is installed - Windows 10 - Microsoft Community.
    The problem is the Win10 machine suddenly show "No Audio Output Devices in installed".
    I followed your information regarding to these issues, but no any results. I tried troubleshooter. I did not find any issue.
    I did uninstall / reinstall audio drivers, download and installed latest Intel drivers, but in Device Manager, all audio devices reported working.
    No available devices listed under SOUND. Sound there is no device listed.
    The issue is not in audio driver since audio show fine in Device Manager, but not in Sound setting.
    I would ask Carlo TJ if can have a suggestion for me.
    ‘System Manufacturer HP Laptop 14-ck0xxx,
    Type: x64-based PC,
    System SKU: 4XW63EA#ABU,
    OS Name Microsoft Windows 10 Pro Version 10.0.19044 Build 19044’
    Maybe you can find some a suggestion for my model, please?
    Any suggestion would be greatly appreciated.
    floare..., Apr 30, 2025
  1. My system says "audio output device not installed" - Similar Threads - system says audio
  2. My system says "audio output device not installed"
    My system says "audio output device not installed": My Asus laptop suddenly decided that my sound output or input was absent. it's not https://answers.microsoft.com/en-us/windows/forum/all/my-system-says-audio-output-device-not-installed/c194228f-2efb-4906-9b94-80e5e851f88f
  3. No audio output device is installed
    No audio output device is installed: Hi,Laptop: Medion P6645 / Windows 10I turned my laptop on this morning and there is a red cross next to my speaker icon.It says speaker setup unknown and in output and input devices there are no options to select.In device manager sound is hidden, unhiding it I then...
  4. No Audio Output Devices in installed
    No Audio Output Devices in installed: I know this has been widely discussed and Carlo TJ Independent Advisor https://answers.microsoft.com/en-us/profile/29478bd8-e990-4de7-b01b-862427c4f74b , Replied on July 1, 2021 on No Audio Output device is installed - Windows 10 - Microsoft Community.The problem is the...
  5. No Audio Output Device is installed
    No Audio Output Device is installed: Been having this problem for about a week now, Have tried pretty much everything from doing stuff in device manager to system recovery. Nothing works and I can't do a windows reset cause others use the computer, Windows 10 version 2004...
  6. Says no audio output device is installed
    Says no audio output device is installed: Woke up this morning to find I couldn't use the volume and there was no audio, Says no audio output device is installed. Below was done early in the morning Microsoft-Windows-Kernel-PnP/Device Configuration Help! How do I get audio back? worked fine yesterday...
  7. No Audio Output Device is Installed
    No Audio Output Device is Installed: So, I know that this is really late, but didn't install the latest update until yesterday just because I was too lazy to deal with it. My problem is pretty much the same as everyone else; my audio just doesn't work and when I hover my cursor over the speaker icon in the...
  8. No audio output device is installed
    No audio output device is installed: I bought a new headset, plugged it in, sound works great. Of course, when ever i'm using a computer something has to fail. And this something was the microphone. Microphone works fine on other devices. It appeared that the mic was not plugged in(yes, I did plug it in). After...
  9. No Audio Output Device is installed
    No Audio Output Device is installed: Hi, Yesterday my sound was working fine, I walked away from my notebook for 15 minutes and came back and the sound icon had a red X against it. The error message when I hover over it is 'No Audio Output Device is installed'. In Device Manager the error message for...
  10. No Audio Output Device is installed
    No Audio Output Device is installed: Hi. Long time ago, I play with upgrading HDD to SSD, GRUB and some other stuff and I failed and messed my computer up. Now my desktop is still using HDD and does not produce any sound. I tried to fix this problem by Googling "No Audio output device is installed" but I...
