Windows 10: my word and power point documents will not respond when I click to open them. I am using...
Discus and support my word and power point documents will not respond when I click to open them. I am using... in Windows 10 Network and Sharing to solve the problem; my word and power point documents will not respond when I click to open them. I am using windows 10.... Discussion in 'Windows 10 Network and Sharing' started by EdwardLukowich, Jan 31, 2020.
  1. my word and power point documents will not respond when I click to open them. I am using...
  2. marinro Win User
    Folder Freeze when trying to click on a Word Document. HELP
    Hi there,
    I came across a very weird bug/issue.
    Use Case
    Step 1: Create a word document on Desktop and name it TestFreeze
    Step 2: Test that you can open the word document and write something like 'Testing freeze folder' ->save it
    Step 3: Create a folder on Desktop and name it FreezeMe
    Step 4: Copy 'TestFreeze' document in the 'FreezeMe' folder
    Step 5: Open the 'FreezeMe' folder and select/click 'TestFreeze' document
    Result: Folder Not Responding
    Additional Information
    I have run some tests and it does not matter:
    • if it is a new or old Microsoft word file
    • if the document has content in it or not
    • if it has a long/short name or special characters
    • it does not matter the folder or the name of the folder in which you put the file in
    I also tried with an excel file and seems that I do not experience the same issue.
    Microsoft version: 16.0.9330.2073
    Windows version: 10.0.17134 Build 17134 with all updates up to date
    If there is anything else I can provide to help sort this out, please do let me know.
    Opened to any suggestions on how to fix this, as it is very frustrating.
    Thanks
    marinro, Jan 31, 2020
  3. Nath Bea Win User
    Wrong "remove from list" document on word mobile.
    To further assist you with your concern about re-enabling files that were removed from the Recent Documents List in Word, we suggest to follow this steps:
    • Click the FILE tab in the program.
    • Click Options from the list on the left side of the screen.
    • On the Word Options dialog box, click Advanced in the list of options on the left.
    • On the Advanced screen, scroll down to the Display section. Select the value in the Show this number of Recent Documents edit box. You can choose to change the value to 0 to disable the list.
    • When you open Word, or select the Open option in the program, there are no documents in your Recent Documents list.
    • To re-enable the list, go back into the Word Options dialog box and enter the desired value (from 0 to 50, inclusive) in the Show this number of Recent Documents edit box on the Advanced screen. If any documents were previously displayed in the Recent Documents
      list, they are added to the list again.
    We're just here if you have further questions.
    Regards.
    Nath Bea, Jan 31, 2020
  4. my word and power point documents will not respond when I click to open them. I am using...
    Opening a Word Document
    Thank you for replying. The first line of my post did say
    • "I need to open a Word Document on a government website to complete a form."
    SheenaRead, Jan 31, 2020
  1. my word and power point documents will not respond when I click to open them. I am using... - Similar Threads - word power point
  2. Microsoft word "not responding" when I "save" a word document.
    Microsoft word "not responding" when I "save" a word document.: Recently when using word I have been unable to save any of my new inputs to a document. I have been using this document for days, and it was all working fine even earlier today.When I click "save" the cursor switches to the "loading hourglass" and stays like that with nothing...
  3. Microsoft word "not responding" when I "save" a word document.
  4. Unable to open photos when i click on them.
    Unable to open photos when i click on them.: When i open the photos folder , I can see the photos and they do get opened. Even from the Quick access the photos open but when i click on any photo from any folder it open photos app but the photo is not visible . The screen goes grey but there is still minimize, close and...
  5. Unable to open photos when i click on them.
  6. Power point and Word not responding.
    Power point and Word not responding.: Hello Sir,On my pc Power point and Word not responding. Please help me. What to do?It is showing msg Repair now, But when I click on that it was closed within second.Please reply as possible as soon.Thank You...
  7. System icons not opening when I click on them
    System icons not opening when I click on them: Hi all, Hoping I could get some help. I've googled around but not been able to find a fix yet. I'm trying to open things from the system tray (WiFi, action centre, date time etc) but unable to open most of them. Further, I can't seem to open and view available networks from...
  8. I am not able to open MS Word documents.
    I am not able to open MS Word documents.: I am having problem opening MS Word documents. It kept kicking me out or not even open. There is a notification "Display driver failed to start; using Microsoft Basic Display Driver instead." Please advise. Thank you! Ken...
  9. I can't edit documents(excel,word,),when i am open them Through sharepoint list.
    I can't edit documents(excel,word,),when i am open them Through sharepoint list.: We can't edit documents(excel,word),when someone open them Through sharepoint list. This message appears when someone click the "edit" in Excel or Word. [ATTACH] This means: We cannot connect to the server. If the error persists,contact your helpdesk. It Works with...
  10. When I open MS Word documents
    When I open MS Word documents: When I now open MS Word documents I find they are all encrypted. How do I get the documents to display normally? https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/when-i-open-ms-word-documents/41b7d182-4393-4b85-a9cf-db993c031280
