Windows 10: Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139
Discus and support Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139 in Windows 10 Gaming to solve the problem; Hi there,I am facing from time to time the BlueScreen Problem in recently. I have tried to compare the event logs and found the minidump file for last... Discussion in 'Windows 10 Gaming' started by Yuqiu Du, Aug 16, 2022.
  1. Yuqiu Du Win User
    Hi there,I am facing from time to time the BlueScreen Problem in recently. I have tried to compare the event logs and found the minidump file for last 3 occurences, and hope you may could help me to adress the Problem.I uploaded the System Event log, minidump and the System Information in the following onedrive folder.Troubleshooting_BBT540_04Many thanks if you can provide any helps
  2. Bluescreen code: 139
    link to the DMP FILE OF THE ERROR: MEMORY.rar
    0x00000139 (0x0000000000000003, 0xfffff8033606f640, 0xfffff8033606f598, 0x0000000000000000).
    BAUTISTA CARNAGHI PAVEGLIO, Aug 16, 2022
  3. KERNEL_SECURITY_CHECK_FAILURE (139)
    Hi MohamedBishr
    Greetings! I am Vijay, an Independent Advisor. I am here to work with you on this problem.
    A. Analysis Results
    File Name: 081819-15328-01.dmp
    IMAGE_NAME: CLASSPNP.SYS
    B. Third Party Drivers
    None
    C. Recommendations
    a. Create a system restore point first so that if something wrong happens you can revert.
    Type restore point in Cortana Search > Create a Restore point > Check whether against your drive, Protection is ON or not. If not ON, click Configure button below to Make it ON > Now press Create to create a restore point
    b. Some third party drivers are causing BSODs. To know if a third party driver is one of the causes - Enable Driver Verifier and generate dump files and upload to Onedrive and share the link here (Don't forget to turn off Driver Verifier after the job is done).
    Do read the instructions carefully particularly how to get back into Windows when you get the crash.
    https://www.tenforums.com/tutorials/5470-enable...
    Disclaimer - This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product
    advertised on the site before you decide to download and install it.
    Vijay_Verma, Aug 16, 2022
  4. Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139
    Hi SunderBiticon
    A. Analysis Results
    File Name: 042319-10796-01.dmp
    *** WARNING: Unable to verify timestamp for BEDaisy.sys
    IMAGE_NAME: BEDaisy.sys
    File Name: 042319-11250-01.dmp
    File Name: 042319-11406-01.dmp
    BEDaisy.sys - Battle Eye
    Drive Date - Mon Feb 25 04:08:41 2019
    C. Recommendations
    1. Create a system restore point so that if something wrong happens you can revert.
    2. The crash is caused by Battle Eye. Update the concerned game to latest so that this driver gets updated.
    Do let me know if you require any further help on this. Will be glad to help you.
  1. Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139 - Similar Threads - Need Help BlueScreen
  2. Help with BSODs: KERNEL_SECURITY_CHECK_FAILURE 139
    Help with BSODs: KERNEL_SECURITY_CHECK_FAILURE 139: Hi thereWin 10 Dell Laptop hitting BSODs several times a week.Need help!Started on 7/4/2022: I don't have a restore-point prior to 7/4/2022.Please Noteicrosoft R Windows Debugger Version 10.0.25136.1001 AMD64Copyright c Microsoft Corporation. All rights reserved.Loading Dump...
  3. Help with BSODs: KERNEL_SECURITY_CHECK_FAILURE 139
  4. Help with BSODs: KERNEL_SECURITY_CHECK_FAILURE 139
  5. Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139
    Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139: Hi there,I am facing from time to time the BlueScreen Problem in recently. I have tried to compare the event logs and found the minidump file for last 3 occurences, and hope you may could help me to adress the Problem.I uploaded the System Event log, minidump and the System...
  6. Need Help for BlueScreen Problem KERNEL_SECURITY_CHECK_FAILURE 139
  7. KERNEL_SECURITY_CHECK_FAILURE 139. Please help!!
    KERNEL_SECURITY_CHECK_FAILURE 139. Please help!!: My PC started randomly crashing a couple months ago, eventually it got to the point where it would crash constantly. I have not been able to successfully troubleshoot it myself, so I came here hoping someone will be able to help me. I ended up doing a clean reset of my entire...
  8. KERNEL_SECURITY_CHECK_FAILURE 139. Please help!!
  9. KERNEL_SECURITY_CHECK_FAILURE 139
    KERNEL_SECURITY_CHECK_FAILURE 139: I'm having a blue screen and the DMP file shows the following: Note: I uploaded the DMP to OneDrive, kindly find the download link below: https://1drv.ms/u/s!AnV55OtEeJkLsxmmrQ1hGngtnSoE?e=TYir0C...
  10. KERNEL_SECURITY_CHECK_FAILURE (139)
    KERNEL_SECURITY_CHECK_FAILURE (139): Hi everybody, im having a issue with my laptop, keeps rebooting randomly, every 1hour if I don't use it. Last night I left the game on for whole night and it didn't restart not even 1 time. After I exit the game this morning and left laptop on it happened again. Device...
