Windows 10: Need help with a display issue
Discus and support Need help with a display issue in Windows 10 Graphic Cards to solve the problem; My old Samsung SyncMaster B2030 is showing something I don't know how to name, so I'll say it's like a galaxy of small shiny white dots. [img]... Discussion in 'Windows 10 Graphic Cards' started by Paultx, Jan 19, 2021.
Need help with a display issue - Similar Threads - Need help display
in Windows 10 Graphic CardsNeed help with a display issue: My old Samsung SyncMaster B2030 is showing something I don't know how to name, so I'll say it's like a galaxy of small shiny white dots. [img] [img] Can you please explain what is that and what can I do to fix it, should it have any fix? TIA. Windows 10 Pro 20H2... -
Display messed up (Need Help)
in Windows 10 Ask InsiderDisplay messed up (Need Help): I built a new computer and installed windows 10 pro from scratch. For some reason the display looks like everything is in 1920x1080 but my monitor is 2560 x 1440. Even when I try to play video games the display is by default showing a different one than my actual monitor.... -
Need help with this issue.
in Windows 10 Ask InsiderNeed help with this issue.: [ATTACH] submitted by /u/_JmartinezJ_ [link] [comments] https://www.reddit.com/r/Windows10/comments/iwj9k1/need_help_with_this_issue/ -
Need help adjusting my display
in Windows 10 Ask InsiderNeed help adjusting my display: My laptop display is broken towards the left side and there are black vertical lines running along the whole length of the screen. Is there any way I can resize Windows 10 to use the part of my display which still works? submitted by /u/geekalert91 [link] [comments]... -
Need help with an issue.
in Windows 10 Ask InsiderNeed help with an issue.: Recently I’ve had an issue where my computer isn’t functioning very well. I’m not able to open any applications but settings and file explorer, so my computer is pretty much completely useless. When I click on any file/application, nothing happens, and the computer reacts as... -
Help: Display Brightness Issue
in Windows 10 Ask InsiderHelp: Display Brightness Issue: Hello, this is my first post here on this subreddit as I've been lurking for some time now. Anyways, whenever I unplug my laptop(Dell Inspiron 15 5000) from the charger, the screen always dims a little bit and I was wondering if this can even be changed as I can't seem to... -
Display not detected. Need Help!
in Windows 10 Drivers and HardwareDisplay not detected. Need Help!: I'm not sure what to classify this topic as. I use my computer mainly for gaming. Just last night my monitor started saying it couldn't be detected when loading a certain game for the first time. As of today the game will load, but now I see my monitor cant be set to 144hz... -
Need help with display settings
in Windows 10 CustomizationNeed help with display settings: I am using File Explorer, and I have a number of separate sessions open, browsing different folders, so I can drag and drop contents from one folder to another. The problem is that the determining the boundaries of File Explorer Windows is very difficult, especially when... -
Display issues please help
in Windows 10 CustomizationDisplay issues please help: I have a 4k 28 inch (left)Display port and a 24 inch Hdmi 1080p(right). Windows thinks my right monitor is very small and it isn't what do i do? [ATTACH][ATTACH][ATTACH]...
