Windows 10: Need help with extending wifi connection through Ethernet cable
Discus and support Need help with extending wifi connection through Ethernet cable in Windows 10 Network and Sharing to solve the problem; Hello everyone. I live in a large home and our wifi can not reach the entire house. Main router is on one side of the home, I'm in the middle and there... Discussion in 'Windows 10 Network and Sharing' started by Imissw7, Dec 8, 2018.
Need help with extending wifi connection through Ethernet cable - Similar Threads - Need help extending
Cannot connect to internet through ethernet cable
in Windows 10 GamingCannot connect to internet through ethernet cable: Hey there, I'm having some serious trouble getting an internet connection properly. So I recently moved and my internet was fine on my pc for months.Now for no apparent reason I'm struggling to get an internet connection.I did have some issues with the cooling on my pc and I... -
in Windows 10 Software and AppsCannot connect to internet through ethernet cable: Hey there, I'm having some serious trouble getting an internet connection properly. So I recently moved and my internet was fine on my pc for months.Now for no apparent reason I'm struggling to get an internet connection.I did have some issues with the cooling on my pc and I... -
in Windows 10 Network and SharingCannot connect to internet through ethernet cable: Hey there, I'm having some serious trouble getting an internet connection properly. So I recently moved and my internet was fine on my pc for months.Now for no apparent reason I'm struggling to get an internet connection.I did have some issues with the cooling on my pc and I... -
Unable to connect to wifi without a ethernet cable
in Windows 10 Network and SharingUnable to connect to wifi without a ethernet cable: Hi, I am currently using a lenovo ideapad 320s. Recently, after updating to windows 21H1, my wifi keeps disconnecting at random times. When this happens, the wifi options will disappear. This has been getting worst recently, and now my wifi does not work at all. The intel... -
Cannot Access Pc ethernet Cable to router through chromecast or pc connected through wifi
in Windows 10 Network and SharingCannot Access Pc ethernet Cable to router through chromecast or pc connected through wifi: I wish to know a solution for connecting and using the content/resources on my pc which is connected through the ethernet cable lan to the router through a pc/chromecast using wifi Using Windows 10 Router ZTE F660 Regards... -
Unable to connect to wifi extender via ethernet cable
in Windows 10 Ask InsiderUnable to connect to wifi extender via ethernet cable: Pretty self-explanatory: The computer recognises the Wifi extender as a wireless network but refuses to connect the computer to the extender via the ethernet cable that I have plugged in. The weird part is that the computer is now telling me that an ethernet connection has... -
Ethernet Cable Connected, But No Ethernet
in Windows 10 Network and SharingEthernet Cable Connected, But No Ethernet: I have my ethernet cable plugged in and my computer detects that it has been plugged in but it just says ethernet no internet. I've had this problem for a while and i believe that it started after an update. Its getting really annoying and ive tried some things across the... -
Need help with connecting laptop to desktop using ethernet cable
in Windows 10 Network and SharingNeed help with connecting laptop to desktop using ethernet cable: So about 6 months ago my internet got shut off for a few days. I was still able to connect to an open wifi from my house. I then connected my laptop to my desktop using an ethernet cable. On the laptop all I had to do was go into the adapter properties and select to share the... -
Wifi not connecting without Ethernet cable
in Windows 10 Network and SharingWifi not connecting without Ethernet cable: Basically what happened before: After updating to Windows 10, my computer was not showing any network options. (The icon says "Not connected - No connections are available) Going into Control Panel/Network and Internet/Network Connections, it then says "Local Area Connection...
