Windows 10: Needing help with Kernel-power (41) related BSODs
Discus and support Needing help with Kernel-power (41) related BSODs in Windows 10 BSOD Crashes and Debugging to solve the problem; So, last week I noticed that a BSOD flashed very quickly out of nowhere and my laptop restarted shortly. Didn't bother me much, but it being a BSOD,... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by wowbaggerBR, Jun 29, 2021.
Needing help with Kernel-power (41) related BSODs - Similar Threads - Needing help Kernel
BSoD -Kernel Power 41
in Windows 10 GamingBSoD -Kernel Power 41: My system suddenly shuts down. No problem with overheating, ram etc I think it is my mobo cause i changed my power supply. Also this happens when i start Blustacks.My logs are on the following public link... -
in Windows 10 Software and AppsBSoD -Kernel Power 41: My system suddenly shuts down. No problem with overheating, ram etc I think it is my mobo cause i changed my power supply. Also this happens when i start Blustacks.My logs are on the following public link... -
KERNEL POWER 41 IRQL BSOD HELP!!!
in Windows 10 GamingKERNEL POWER 41 IRQL BSOD HELP!!!: HELP my PC keeps BSOD. I have tried everything suggested by previous posts but IRQL BSOD keeps happeningHere is the V2 log collector zipped info for you geniuses to analyse https://www.dropbox.com/s/baefo0imltwybr2/DESKTOP-SG83S1H-%282023-03-14_07-09-40%29.zip?dl=0This... -
in Windows 10 Software and AppsKERNEL POWER 41 IRQL BSOD HELP!!!: HELP my PC keeps BSOD. I have tried everything suggested by previous posts but IRQL BSOD keeps happeningHere is the V2 log collector zipped info for you geniuses to analyse https://www.dropbox.com/s/baefo0imltwybr2/DESKTOP-SG83S1H-%282023-03-14_07-09-40%29.zip?dl=0This... -
Kernel Power 41 Help!
in Windows 10 BSOD Crashes and DebuggingKernel Power 41 Help!: Hi I recently installed The Crew 2 and I've been playing it on medium settings and recently my computer started to shutdown itself without any notice and all the sounds get glitched out and when I restart and check the event viewer it tells me I had a Kernel Power 41 error... -
BSOD Kernel-Power 41
in Windows 10 BSOD Crashes and DebuggingBSOD Kernel-Power 41: This started when i had clean install windows 10 a few weeks ago where laptop randomly BSOD and reboot it self, i find this in event viewer: - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> - <System> <Provider Name="Microsoft-Windows-Kernel-Power"... -
in Windows 10 BSOD Crashes and DebuggingBSOD Kernel-Power 41: This started a few days ago where PC will crash and after reboot, i find this in event viewer: Log Name: System Source: Microsoft-Windows-Kernel-Power Date: 13/05/2019 16:48:11 Event ID: 41 Task Category: (63) Level: Critical... -
Every shutdown considered kernel power 41, BSOD related?
in Windows 10 Installation and UpgradeEvery shutdown considered kernel power 41, BSOD related?: Every time I shut down my computer and restart it (via the 'shutdown' command in the start menu) I get a Kernel Power critical error in my event viewer. This has seemingly no other negative effects, but seeing it's a critical error made me feel like I ought to ask around... -
in Windows 10 BSOD Crashes and DebuggingBSOD Kernel-Power 41: Hi, I've been experiencing random BSOD's, can't tell what is causing it: Mostly under BugCheckcode 10 and 80. Any thoughts? I did not add any hardware or new drivers recently......
