Windows 10: Never using battery power in a laptop
Discus and support Never using battery power in a laptop in Windows 10 Support to solve the problem; I have a brand new laptop and I run it on mains power all the time (constantly plugged in) does this degrade the battery in any way as I have no way of... Discussion in 'Windows 10 Support' started by ICIT2LOL, Sep 27, 2020.
  1. ICIT2LOL Win User
    I have a brand new laptop and I run it on mains power all the time (constantly plugged in) does this degrade the battery in any way as I have no way of taking the battery out because it is housed inside the machine.
    I have Googled this and have a number of different thoughts on the matter so any thoughts on what I should do ie occasionally use it on battery power?
    Am asking because it was quite expensive to buy this device - an Asus X721A Vivo notebook.
  2. laptop battery wont charge after latest update
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    6. Under the Batteries category, right-click all of the Microsoft ACPI Compliant Control Method Battery listings, and select Uninstall (it’s okay if you only have 1).
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    FreeBooter, Sep 27, 2020
  3. Battery Won't Charge Fully
    Step 1
    Step 2
    Step 3
  4. Never using battery power in a laptop
    Step 1
    Step 2
    Step 3
  1. Never using battery power in a laptop - Similar Threads - Never using battery
  2. My laptop is slow on battery power
    My laptop is slow on battery power: For example, when I'm playing games or just watching something when it's plugged in it works fine but when it's on battery power it turns super slow. I have tried various methods such as updating my device, turning off the power saver, and various other methods but they don't...
  3. My laptop is slow on battery power
  4. my battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...
    my battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...: I have a hp notebook da 1058tu laptop its battery is dead it never charges up the windows update asks for 40% battery. https://answers.microsoft.com/en-us/windows/forum/all/my-battery-is-dead-and-i-use-my-laptop-on-ac-power/cb183f9e-38c0-43af-a19e-b3c87270ee82
  5. my battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...
  6. my battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...
  7. Battery and Power Question for laptops
    Battery and Power Question for laptops: If I were to set the "when I close the lid" setting to do nothing, but set the "Hibernate after this amount of time" to 10 min. Will the computer hibernate after the 10 min if I shut the lid? Or will it continue to run? Basically I want to be able to shut the lid but if I...
  8. Laptop is using battery power even when it is plugged in and fully charged.
    Laptop is using battery power even when it is plugged in and fully charged.: Hi guys, couple of months ago i bought a new gaming laptop that have a GTX1050 4gb graphic. But now a days I noticed that when i play heavy games like GTA V, Far cry 5, Resident evil 3 etc. my laptop is using battery power even I plugged in. When i do less power demanding...
  9. Laptop crashes on battery power
    Laptop crashes on battery power: I have Windows 10 running on my laptop. After a recent update the battery life icon vanished. I followed the instructions in the settings to switch it back on but now the laptop crashes without warning. It acts like the battery is dead but it is a months old battery and it...
  10. Laptop Battery, Does It Hurt the Battery to Use External AC Power?
    Laptop Battery, Does It Hurt the Battery to Use External AC Power?: I haven't used my laptop much yet, only a little bit to set up some bookmarks, wallpaper, etc. Every time I use it, I plug it into the wall. I'm at home so it's not inconvenient, and I figured it would save on the battery life. Is it harmful to the battery to keep plugging...
