Windows 10: "No audio output device is installed" Help?
Discus and support "No audio output device is installed" Help? in Windows 10 Drivers and Hardware to solve the problem; I have recently upgraded my PC to Windows 10 and just this morning my audio is nonexistent with the error "No audio output device is installed". My... Discussion in 'Windows 10 Drivers and Hardware' started by SavvyRose1, Sep 19, 2020.
  1. "No audio output device is installed" Help?
    I have recently upgraded my PC to Windows 10 and just this morning my audio is nonexistent with the error "No audio output device is installed". My audio didn't have any problems after upgrading till I put it to sleep for the night and found it broken the next day. I have used the troubleshooter multiple times in multiple ways and that has failed to fix anything. I have updated all my drivers and even manually uninstalled/reinstalled them as well. Switching my headset to other usb ports I had available on my pc didn't work either. Yes My head set works I tested it on other computers/phones I have no Idea on what to do... I'm desperate for help and suggestions... and since I just recently upgraded to win10 I have no "rollback" option to a previous update...
  2. No Audio Output Device is Installed
    You will need to select Windows 8 from the drop down list while installing the driver in compatibility mode.
    I would suggest you to try setting the speaker as default audio output by following the steps below and check if it helps.
    1. Right click on the sound icon on the right bottom corner of the taskbar.
    2. Select "playback devices".
    3. If "speaker" is not set as the default device, highlight it and click "set as default".
    5. Save the changes.
    Let us know the result.
    Wungraileng Vashi, Sep 19, 2020
  3. No audio output device is installed
    Hi Oscar,
    I'm Charles, an Independent advisor trying to help.
    Please, check the instructions and suggestions in this article, it is a website managed by a Windows MVP, so it is reliable information.
    https://www.thewindowsclub.com/no-audio-output-...
    I hope the steps work for you
    Attentive to your comments
    Have a happy day
    Best Regards,
    Charles.
    CharlesJones32, Sep 19, 2020
  4. fireberd Win User
    A screenshot of the Device Manager, Sounds section is still needed. Can't really offer a suggestion until I see what is showing there now.
    e.g this is mine It shows AMD which the audio for HDMI, Realtek and Tranzport which is a wireless controller for my recording studio program.
    "No audio output device is installed" Help? [​IMG]
    fireberd, Sep 19, 2020
  1. "No audio output device is installed" Help? - Similar Threads - audio output device
  2. [HELP] No Audio Output Device is installed.
    [HELP] No Audio Output Device is installed.: I'm experiencing an issue that says I don't have an audio device installed. I couldn't listen to anything on YouTube, Netflix, or anything for that matter. I resetted the device twice and reinstalled Windows. I'm using a Kano PC powered by Windows 10 Pro. I want to get this...
  3. Need help with "No Audio Output Device is installed"
    Need help with "No Audio Output Device is installed": So I was on my pc to check to start class then i see that I can't put my volume up. I thought it could just be an update error so I checked the updates. (which last checked was like 10 mins b4 i got back on, and the update would almost never work) when I tried to do the...
  4. No Audio Output Device is installed
    No Audio Output Device is installed: Been having this problem for about a week now, Have tried pretty much everything from doing stuff in device manager to system recovery. Nothing works and I can't do a windows reset cause others use the computer, Windows 10 version 2004...
  5. no audio output device is installed notification HELP
    no audio output device is installed notification HELP: Yesterday I had audio and today no audio https://answers.microsoft.com/en-us/windows/forum/all/no-audio-output-device-is-installed-notification/a16dc5ab-c586-4346-acf0-9ff7245d933e
  6. No Audio Output Device is installed PLEASE HELP ;_;
    No Audio Output Device is installed PLEASE HELP ;_;: I've been working with computers for a while but this has me stumped. Motherboard is a FM2A58M-VG3+ R2.0 Not only do I not have any sound, I also have 9 unknown devices in the AudioBus which I have attempted to update to no avail, using windows update, various update...
  7. no audio output device is installed help
    no audio output device is installed help: My pc says no audio output device is installed help https://answers.microsoft.com/en-us/windows/forum/all/no-audio-output-device-is-installed-help/5f42359e-d92a-4385-9fe1-32fd410cfaef
  8. No audio output device is installed
    No audio output device is installed: I bought a new headset, plugged it in, sound works great. Of course, when ever i'm using a computer something has to fail. And this something was the microphone. Microphone works fine on other devices. It appeared that the mic was not plugged in(yes, I did plug it in). After...
  9. No Audio Output Device is installed
    No Audio Output Device is installed: Hi, Yesterday my sound was working fine, I walked away from my notebook for 15 minutes and came back and the sound icon had a red X against it. The error message when I hover over it is 'No Audio Output Device is installed'. In Device Manager the error message for...
  10. No Audio Output Device is installed
    No Audio Output Device is installed: Hi. Long time ago, I play with upgrading HDD to SSD, GRUB and some other stuff and I failed and messed my computer up. Now my desktop is still using HDD and does not produce any sound. I tried to fix this problem by Googling "No Audio output device is installed" but I...
