Windows 10: No monitor audio through Displayport, HDMI audio works perfectly fine.
Discus and support No monitor audio through Displayport, HDMI audio works perfectly fine. in Windows 10 Ask Insider to solve the problem; Recently, my monitor stopped outputting sound through Displayport. It worked for a long time, but it just randomly stopped one day. It works completely... Discussion in 'Windows 10 Ask Insider' started by /u/DabbingCats2005, Dec 16, 2020.
No monitor audio through Displayport, HDMI audio works perfectly fine. - Similar Threads - monitor audio through
No audio through DisplayPort
in Windows 10 GamingNo audio through DisplayPort: More specific:-My laptop is HP Folio 9470m, running Windows 10 22H2. There is no HDMI but DiplayPort on this device. Other video output is VGA.-I connect it through a DP to HDMI adapter, then to HDMI cable to the TV. There is video appear, but audio still only laptop built-in... -
in Windows 10 Software and AppsNo audio through DisplayPort: More specific:-My laptop is HP Folio 9470m, running Windows 10 22H2. There is no HDMI but DiplayPort on this device. Other video output is VGA.-I connect it through a DP to HDMI adapter, then to HDMI cable to the TV. There is video appear, but audio still only laptop built-in... -
in Windows 10 Drivers and HardwareNo audio through DisplayPort: More specific:-My laptop is HP Folio 9470m, running Windows 10 22H2. There is no HDMI but DiplayPort on this device. Other video output is VGA.-I connect it through a DP to HDMI adapter, then to HDMI cable to the TV. There is video appear, but audio still only laptop built-in... -
No audio in monitor's speaker for first few seconds when using HDMI/Displayport
in Windows 10 GamingNo audio in monitor's speaker for first few seconds when using HDMI/Displayport: I bought a new monitor benq EX2710Q and it has in built speakers. If i play anything first few seconds there is no audio and after that i can hear perfectly. I thought this was an issue with cable but then i tried same cable with my xbox and macbook and it all worked... -
Displayport & HDMI Audio not working on monitor speakers only.
in Windows 10 Drivers and HardwareDisplayport & HDMI Audio not working on monitor speakers only.: I am running an AORUS Z390 PRO mobo, i9-9700k and 2060Super. I can't seem to get any audio to play out of my monitor speakers yes it does have speakers the audio works fine out of every other audio output lineout and headphone but for some reason monitor sound doesn't. It... -
Windows 10 HDMI audio through second monitor
in Windows 10 Drivers and HardwareWindows 10 HDMI audio through second monitor: I have two monitors, one connected through displayport, one connected through HDMI. The second monitor has speakers connected to it and is used as the sound output, this is set as the default sound device NVIDIA High Definition Audio. The monitors are used as extended... -
Monitor is not working with DisplayPort to HDMI adapter
in Windows 10 Drivers and HardwareMonitor is not working with DisplayPort to HDMI adapter: I have a HP EliteDisplay E222 and it is not able to recieve signals using a HDMI to DisplayPort adapter. I have tried plugging in the DisplayPort side of the adapter into my computer and into my graphics card and both of them give me no signal and that makes me think it is... -
"The Audio Service is not running." even though audio is perfectly fine.
in Windows 10 Drivers and Hardware"The Audio Service is not running." even though audio is perfectly fine.: [ATTACH] I keep getting the message "The Audio Service is not running." even though my audio is working perfectly fine and I can change it and everything, the logo claims its muted but the audio is working fine as I said before. Its a bit annoying and I would appreciate any... -
Audio through HDMI to TV stops working.
in Windows 10 BSOD Crashes and DebuggingAudio through HDMI to TV stops working.: I'm having trouble with my audio going from my computer to my TV through the HDMI cable following the latest update. When I restart the computer it works fine for a time, but after it sleeps and wakes up the audio starts going back through the computer speakers and the audio...
