Windows 10: No sound from Pc unless sound setting are open.
Discus and support No sound from Pc unless sound setting are open. in Windows 10 Ask Insider to solve the problem; I don't get any sound from my PC unless I open sound settings. I don't know what's going on and it's very frustrating. I would open a game and not... Discussion in 'Windows 10 Ask Insider' started by /u/LordOfSword525, Aug 29, 2020.
No sound from Pc unless sound setting are open. - Similar Threads - sound unless sound
Cannot open sound settings
in Windows 10 CustomizationCannot open sound settings: I recently had to factory reset my computer, but ever since i reinstalled windows I can no longer open the settings from the taskbar. This is important because I have a goxlr and I no longer access the 'app volume and devices preferences', so I can't assign different apps to... -
No sound unless Sound Settings is open?
in Windows 10 Ask InsiderNo sound unless Sound Settings is open?: Hello, So I have had this problem for like 4 months and now I finally want to fix it. Basically, when windows 10 boots up, my sound works perfect but as soon as a video game, zoom or discord opens up, my sound stops working unless I have the Sound Settings in System... -
problem with sound settings not opening
in Windows 10 Customizationproblem with sound settings not opening: i try to open sound settings and then command prompt opens then closes i already scanned for virus which found 17 virus , i used Malwarebytes , i also restarted my computer , and i even checked corrupted files windows did found some corrupted files which were repaired. i... -
Can not open "taskbar setting" and "open sound setting" from taskbar
in Windows 10 CustomizationCan not open "taskbar setting" and "open sound setting" from taskbar: I have a problem with my windows 10. I Can not open "taskbar setting" and "open sound setting" from the taskbar. when I want to open them a black page appears and closes instantly.... -
No sounds from HDMI to TV unless restart
in Windows 10 Ask InsiderNo sounds from HDMI to TV unless restart: Hi, I have a problem with my windows and it really annoying. I connected HDMI to my TV just for sometime i watch movie in my computer. But if i didnt turn on TV before turn on my PC, i cant play sounds on my TV, i have to restart my PC and keep my TV turned on. Its really... -
Sound ICON in Control panel will not open sound settings.
in Windows 10 CustomizationSound ICON in Control panel will not open sound settings.: Control panel will open, but when I click on sound, It errors with [ATTACH] This has been bugging me for awhile now, and I have struggled trying to fix it... I need to boost the mic I use for skype as the volume is too low. Windows 10 64 bit OS Several other Icons in... -
Cannot open sound settings from control panel
in Windows 10 CustomizationCannot open sound settings from control panel: Hello, for the longest time I have been unable to open the sound settings in the control panel. My sound works perfectly fine and I can change the speaker and microphone through other methods. I can here sound and my microphone works fine but since windows 10 I am unable to... -
Sound Mixer Not Affecting Programs Sounds Unless Opened
in Windows 10 CustomizationSound Mixer Not Affecting Programs Sounds Unless Opened: Hi, I recently installed Windows on a new computer (acer Nitro V17 VN7-793G), and installed all given drivers on Acer's website. Here's the issue: I muted the system sounds through the mixer, but when an event triggering system sounds occur, the sound do happen. Except... -
in Windows 10 CustomizationSound Mixer Not Affecting Programs Sounds Unless Opened: Hi, I have recently installed windows, on a new computer, downloaded the drivers from the official contructor website (it's an Acer Nitro V17 VN7-793G). I quickly noticed that I had sounds that resembled the Windows System sounds, but I had disabled the system sounds through...
