Windows 10: No sound through monitor speakers after monitor turns off by power plan setting
Discus and support No sound through monitor speakers after monitor turns off by power plan setting in Windows 10 Performance & Maintenance to solve the problem; I had a one monitor setup with power plan setting to turn off monitor after 5 mins of inactivity. The monitor is a Iiyama G-Master Silver Crow... Discussion in 'Windows 10 Performance & Maintenance' started by RO xX Horia Xx, Apr 29, 2020.
No sound through monitor speakers after monitor turns off by power plan setting - Similar Threads - sound through monitor
Monitor turns green, static comes through speakers
in Windows 10 Software and AppsMonitor turns green, static comes through speakers: Windows 10CPU: 7800X3DGPU: 7900XTXG.Skill DDR5- 6000 RAMALL BIOS AND UPDATES HAVE BEEN INSTALLED.This is a brand new system, with all new parts. There are no random drivers or system files that may be left over from a prior build.While playing games, browsing the internet, or... -
Monitor turns on immediately after power plan and can not keep being turned off
in Windows 10 GamingMonitor turns on immediately after power plan and can not keep being turned off: I have pc running on windows 11 but the problem is not related to windows 11, because since the first day I assembled the pc, the problem have been existed. The details are as following: 1. The display is set to turn off after 2 minutes in power plan balanced mode and system... -
in Windows 10 Software and AppsMonitor turns on immediately after power plan and can not keep being turned off: I have pc running on windows 11 but the problem is not related to windows 11, because since the first day I assembled the pc, the problem have been existed. The details are as following: 1. The display is set to turn off after 2 minutes in power plan balanced mode and system... -
Sound with monitor's speakers
in Windows 10 CustomizationSound with monitor's speakers: how can i play music on both lg monitors https://answers.microsoft.com/en-us/windows/forum/all/sound-with-monitors-speakers/85a3c4f7-d1d6-4034-ba46-b2805d2c40f3 -
Monitor sound wont turn off
in Windows 10 Ask InsiderMonitor sound wont turn off: I just recently got a new monitor that has built in speakers. i use them when im not in calls or just playing casual. but when im in my sound settings and i make Realtek Speakers (the device ive always used) the monitor still has volume. Can anyone help me? submitted by... -
Monitor powers on after computer turns it off
in Windows 10 Performance & MaintenanceMonitor powers on after computer turns it off: Trying to find how to keep monitor off after I lock the PC. What I do: 1. Monitor powers off after 1 minute when PC is locked 2. In few seconds computer plays sound like it detects new hardware, monitors wakes up and shows "No Cable Connected". 3. Then monitor turns off.... -
Windows ignores the time set in power plan options to turn off my monitors
in Windows 10 Ask InsiderWindows ignores the time set in power plan options to turn off my monitors: I set the time to turn off my monitors to 10min in windows power plan options and it doesn’t work. Also tried setting the power button to turn off the monitors but in vain, when I press the power button after setting it to turn off my monitors, the monitors go black for a... -
Monitors will not turn off per power settings
in Windows 10 Performance & MaintenanceMonitors will not turn off per power settings: My monitors do not enter power save, per my power settings. I've run troubleshooter, reset to default, changed settings, updated drivers, checked reliability monitor, unplugged all usb device, issue persists. Can anyone help with this?... -
Monitor turns off after 10min (not screensaver or power settings)
in Windows 10 SupportMonitor turns off after 10min (not screensaver or power settings): Hello just few days ago monitor (Asus PG278Q) started turning off after 10 min while watching media or idle. Checked screensaver: set to 'none' Checked power settings: max performance, set to never shut down or sleep. What else can turn off monitor except screensaver...
