Windows 10: No sound with HDMI connection and is not a driver problem
Discus and support No sound with HDMI connection and is not a driver problem in Windows 10 BSOD Crashes and Debugging to solve the problem; Windows 10 Pro-64-bit is not seeing system speakers on a Viewsonic VA2246M LED Monitor with built-in Speakers, Have a case number but have not heard... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Gil "Keep it Simple", May 28, 2023.
No sound with HDMI connection and is not a driver problem - Similar Threads - sound HDMI connection
in Windows 10 GamingNo sound with HDMI connection and is not a driver problem: Windows 10 Pro-64-bit is not seeing system speakers on a Viewsonic VA2246M LED Monitor with built-in Speakers, Have a case number but have not heard from tech support. Had external speakers that worked before and the HDMI connection is seen. by the system. Pkenty of space on... -
in Windows 10 Software and AppsNo sound with HDMI connection and is not a driver problem: Windows 10 Pro-64-bit is not seeing system speakers on a Viewsonic VA2246M LED Monitor with built-in Speakers, Have a case number but have not heard from tech support. Had external speakers that worked before and the HDMI connection is seen. by the system. Pkenty of space on... -
Sound in monitor connected with a hdmi cable
in Windows 10 GamingSound in monitor connected with a hdmi cable: When I connect the laptop to a monitor with a hdmi cable, I can watch the video but don´t listen the audio.I´ve reviewed the driver sound intel R for displays and it show that it´s windows/system32 but my laptop is windows System 64.I´m believed that perhaps the problem is on... -
in Windows 10 Software and AppsSound in monitor connected with a hdmi cable: When I connect the laptop to a monitor with a hdmi cable, I can watch the video but don´t listen the audio.I´ve reviewed the driver sound intel R for displays and it show that it´s windows/system32 but my laptop is windows System 64.I´m believed that perhaps the problem is on... -
in Windows 10 Drivers and HardwareSound in monitor connected with a hdmi cable: When I connect the laptop to a monitor with a hdmi cable, I can watch the video but don´t listen the audio.I´ve reviewed the driver sound intel R for displays and it show that it´s windows/system32 but my laptop is windows System 64.I´m believed that perhaps the problem is on... -
HDMI to TV - sound problem
in Windows 10 BSOD Crashes and DebuggingHDMI to TV - sound problem: Using the HDMI port I connected my laptop to my TV set to watch a sports event. The sound still came from the laptop rather than through the TV, whereas previously it did come through the TV speakers. What is happened and how is it fixed, please?... -
Sound Problems with HDMI and DisplayPort
in Windows 10 Drivers and HardwareSound Problems with HDMI and DisplayPort: Dear Windows Community, I have encountered a strange problem: A few days ago I built a new PC with Windows 10 which is now connected to three displays 2x DisplayPort and 1x HDMI. One of these displays has speakers connected via DisplayPort, another doesn't have internal... -
No sound from HDMI connected monitor
in Windows 10 CustomizationNo sound from HDMI connected monitor: The sound quit working on my HDMI connected monitor. It says headphone or speaker unplugged. I'm pretty sure some update caused it. I have a Dell Inspiron Desktop.... -
HDMI sound issue - need to reinstall driver every time I connect it
in Windows 10 BSOD Crashes and DebuggingHDMI sound issue - need to reinstall driver every time I connect it: I have a strange issue - every time I connect my laptop to my TV via HDMI, the sound cuts out rather than automatically coming from the TV I follow the audio troubleshooting steps and this always works - apparently the troubleshooter reinstalls the drivers. Even after a...
