Windows 10: No System Sound Through any Audio Outputs
Discus and support No System Sound Through any Audio Outputs in Windows 10 Ask Insider to solve the problem; I currently use a DAC -X6 for my headphones and have been using this setup for over a year without this issue. I used my PC last night just fine with... Discussion in 'Windows 10 Ask Insider' started by /u/fainty_eu, Mar 22, 2020.
No System Sound Through any Audio Outputs - Similar Threads - System Sound Through
output sound playing through input
in Windows 10 Gamingoutput sound playing through input: Hello.I have a problem with my sound : when I play something on my headphone the mic catches it. for exemple if i have music and being on discord at the same time, the other guy in the call hears my music. I already tried to check if the "listen to device" options was... -
in Windows 10 Software and Appsoutput sound playing through input: Hello.I have a problem with my sound : when I play something on my headphone the mic catches it. for exemple if i have music and being on discord at the same time, the other guy in the call hears my music. I already tried to check if the "listen to device" options was... -
in Windows 10 Drivers and Hardwareoutput sound playing through input: Hello.I have a problem with my sound : when I play something on my headphone the mic catches it. for exemple if i have music and being on discord at the same time, the other guy in the call hears my music. I already tried to check if the "listen to device" options was... -
Output Audio Playing Through Input Audio
in Windows 10 Drivers and HardwareOutput Audio Playing Through Input Audio: I've been having a problem where any audio played through my headset also gets output through my microphone. I've tried testing audio from multiple sources and outputting it to multiple sources, but the problem always persists. It looks like an issue with Windows... -
System audio/sound plays through microphone
in Windows 10 Drivers and HardwareSystem audio/sound plays through microphone: Hi Microsoft, I have been trying this issue for a while, this is going to be my last resort. Basically, my headset Mic picks up anything that is playing in my computer. no, There is no audio bleed from the headphones & if I am in a call in a discord for eg. they can hear... -
Sound Blaster audio output
in Windows 10 Drivers and HardwareSound Blaster audio output: I have a Dell Computer with Windows 10. Started out with Windows 7 and with automatic updates over the years to Windows 10. Problem: My sound system is Creative Sound Blaster “Recon3D PCIe.” After the last Windows update the sound has been unreliable, such as no sound... -
Realtek Audio will not output any sound suddenly
in Windows 10 Ask InsiderRealtek Audio will not output any sound suddenly: Today when I turned on my PC, the Realtek audio will not produce any sound. In the volume mixer it shows that there is not even any sound being detected by Windows. When I switch devices to my monitor, it has sound, but not with my headphones plugged into my motherboard. I... -
Sound Blaster ZXR no sound through Optical output
in Windows 10 Drivers and HardwareSound Blaster ZXR no sound through Optical output: Since i updated to Windows 10 1903 from 1809 my Creative Sound Blaster Z X R audio card has issues with sound output through Optical S/PDIF Out jack. I set this through the Sound Blaster Pro Studio control panel under Cinematic Encoder to Dolby Digital Live to get sound... -
audio output system
in Windows 10 Drivers and Hardwareaudio output system: hi, i have problem with my notebook s sound system. it says no audio output device is installed but when i click it i cant do anything , i cant download or update audio driver...
