Windows 10: Not able to open sound settings in control panel
Discus and support Not able to open sound settings in control panel in Windows 10 Customization to solve the problem; I recently built a new computer and I have windows 10 version 1903 build 18362.267. It lets me open the control panel but when I click on sound... Discussion in 'Windows 10 Customization' started by crazytimtimtim, Aug 5, 2019.
Not able to open sound settings in control panel - Similar Threads - able open sound
Sound control panel not opening
in Windows 10 GamingSound control panel not opening: So I just noticed that the sound control panel is not opening, I tried right clicking the volume icon on the taskbar, and click sounds. I also tried opening it from the sound settings. Anything I can do?... -
in Windows 10 Software and AppsSound control panel not opening: So I just noticed that the sound control panel is not opening, I tried right clicking the volume icon on the taskbar, and click sounds. I also tried opening it from the sound settings. Anything I can do?... -
in Windows 10 CustomizationSound control panel not opening: So I just noticed that the sound control panel is not opening, I tried right clicking the volume icon on the taskbar, and click sounds. I also tried opening it from the sound settings. Anything I can do?... -
Sound Control Panel
in Windows 10 CustomizationSound Control Panel: Ever since the new windows updates, Sound Control Panel , also known in the bottom right (from sounds - speaker) as Playback Devices / Recording Devices, this tab has been taken out and we were given some option not many care about (even if they do, a lot of people never... -
Sound ICON in Control panel will not open sound settings.
in Windows 10 CustomizationSound ICON in Control panel will not open sound settings.: Control panel will open, but when I click on sound, It errors with [ATTACH] This has been bugging me for awhile now, and I have struggled trying to fix it... I need to boost the mic I use for skype as the volume is too low. Windows 10 64 bit OS Several other Icons in... -
Control Panel Sounds
in Windows 10 CustomizationControl Panel Sounds: Device Disconnect makes a sound while computer is in sleep mode. How do I turn it off? https://answers.microsoft.com/en-us/windows/forum/all/control-panel-sounds/4c65c3d3-48e9-43c9-8531-bb29344b98a1 -
Cannot open sound settings from control panel
in Windows 10 CustomizationCannot open sound settings from control panel: Hello, for the longest time I have been unable to open the sound settings in the control panel. My sound works perfectly fine and I can change the speaker and microphone through other methods. I can here sound and my microphone works fine but since windows 10 I am unable to... -
Sound Control Panel
in Windows 10 Drivers and HardwareSound Control Panel: Hi.Running a Windows 10 computer.Running headless using Remote Desktop.Only use the computer as a music server.Have a dac connected to computer.In sound panel under playback it's only option is Remote Audio.Dac and other options are not there.Right click to show disabled and... -
No sound, No Control Panel
in Windows 10 SupportNo sound, No Control Panel: Installed Win10 and have the following problems. 1) I have no sound; Sound icon on task bars says "No audio Output Device Installed." When I run troubleshooter, it says Troubleshooting couldn't detect the problem. 2) Control Panel: When I click on control panel it...
