Windows 10: PC turns on fans running at full speed but no display for monitor, no lights from mic,...
Discus and support PC turns on fans running at full speed but no display for monitor, no lights from mic,... in Windows 10 Software and Apps to solve the problem; After hurricane Milton my friends booted up his PC after he got his power back and his monitor says no display detected, his keyboard or mouse aren't... Discussion in 'Windows 10 Software and Apps' started by Anthony C4, Oct 14, 2024.
  1. PC turns on fans running at full speed but no display for monitor, no lights from mic,...
    After hurricane Milton my friends booted up his PC after he got his power back and his monitor says no display detected, his keyboard or mouse aren't lighting up either. He went out got a new motherboard and CPU as well as RAM just to finish building it and discover the same problem again. He also tried brand new HMDI cords with the same result. Could it be he needs to reinstall windows on it or is it something else. Let me know any other details you may need to help solve.CPU: AMD Ryzen 5 7000RAM: Corsair Vengence RGB DDR5 16 GB x2Motherboard: B650 Plus wifi TufGPU: MSI GAMING X GeForce GTX 1
  2. RichLentz Win User
    My Windows PC Fan is running at High Speed after a few hours of "Sleep"
    Three times in the last two weeks when I go to use my Desktop PC with Windows 11 PRO, with all the latest updates, the cooling fan is running at Full speed. The power light is no longer blinking and is on steady, which usually means the PC just has the Display turned off. Tapping the power button, a key on the keyboard or even the mouse does not "Wake Up" the display or computer. I need to hold the power button for a few seconds, long enough that the power light goes off, and then restart the PC. WORSE, When I shut down the PC at night to avoid this issue, the next morning the power button is light, the fan is not running, HOWEVER, Tapping the power button, a key on the keyboard or even the mouse does not "wake Up" the computer. Again, I have to hold the power button for a few seconds, long enough that the power light goes off, and then restart the PC.
    What bugs did Microsoft put in the Update to Windows 11 Pro two weeks ago?
    RichLentz, Oct 14, 2024
  3. Night Light Setting and Third Monitor.
    Hi Reagan,
    We would like to ask you some questions in order assist you properly:
    • Did Night light work previously on all three monitors?
    • Have you made any recent changes to your PC?
    • Are you getting an error message on the third monitor regarding Night light?
    • Is the third monitor being detected by your PC?
    • What troubleshooting steps have you performed so far?
    While waiting for your response, we suggest that you try to connect your third monitor to what you are using on the 2 working monitors to see if it is only a loose connection issue.
    Regards.
    Rolando Vil, Oct 14, 2024
  4. Eirith . Win User
    PC turns on; peripherals won't light up or display anything
    I was on my pc and I shut it down before I left. I came back, and went to power it on, and everything inside the pc works. The fans turn on and light up, CPU cooler displays liquid temps, GPU fans spin and light up, however, my mouse, keyboard, mic, and monitors have zero signal. I have completed dusted it, cleared any residual power via powering off, removing the power source, disconnecting all peripherals, holding the power button for 10-15sec and then powering it back on. I have cleared the CMOS battery. I have reseated the GPU, and I have moved the GPU to a different PCIe slot. I have reseated the RAM as well as changing what slots my RAM are in(ensuring they're in the proper channels). The motherboard has no debug LED panel. I have double checked all PSU -> Motherboard connections. This PC is about three months old running Windows 11. I am at a loss for what to try, I've exhausted Google and Youtube to the best of my ability. Everything I have found, I have done except taking it to the manufacturer which is NZXT. I have contacted them, and they gave me trouble shooting steps to follow, which I have done except reseating the CPU because I don't want to spill liquid inside of my pc(probably wouldn't happen, but I don't want to risk it unless it is a last resort.
    Spec List:
    OS: Windows 11 Home
    PSU: 750W Gold
    MB: Gigabyte B650 UC AD
    CPU: AMD Ryzen 7 7800X3D
    GPU: 4070 Ti
    RAM: 32GB DDR5 5200MHz
    Storage: 1TB NVMe M.2 SSD
    Eirith ., Oct 14, 2024
  1. PC turns on fans running at full speed but no display for monitor, no lights from mic,... - Similar Threads - turns fans running
  2. PC Display cuts off then fans run at full speed, PC then Resets its self-afterwards.
    PC Display cuts off then fans run at full speed, PC then Resets its self-afterwards.: I have lately been having this issue where my PC keeps resetting itself. It's been happening while gaming, within 5 minutes of any game. My display cuts off then the fans run at full speed. Shortly afterwards my PC will then reset itself. I have never had any issues...
  3. PC Display cuts off then fans run at full speed, PC then Resets its self-afterwards.
  4. PC turns on fans running at full speed but no display for monitor, no lights from mic,...
    PC turns on fans running at full speed but no display for monitor, no lights from mic,...: After hurricane Milton my friends booted up his PC after he got his power back and his monitor says no display detected, his keyboard or mouse aren't lighting up either. He went out got a new motherboard and CPU as well as RAM just to finish building it and discover the same...
  5. Fan running at full speed all the time
    Fan running at full speed all the time: My laptop was running fine and dandy, no loud fan noise, fan would rotate at full speed only when i play games and even at that times fan wouldn't make that much of noise. Untill today's morning when the windows 10 latest update got installed automatically and now fan is...
  6. Fan running at full speed all the time
  7. Fan running at full speed all the time
  8. Fans and lights but no display
    Fans and lights but no display: Hello, so i was just playing my game when it crashed and i had just today installed a HWID spoofer, when my game crashed my cheats wont start up on the spoofed HWID so therefore i restarted my computer. the pc then just stayed on a black screen for 10 mins so i held the...
  9. fan is running at full speed
    fan is running at full speed: I have a problem with a fan because it is running at full speed all the time. It is an old problem which I am unable to fix. I think the OS cannot detect the hardware and force the fan to run at full speed. It is Dell Precision T3500, Windows 10, ver. 10.0.17763. I...
  10. Monitors turn off and every system fan goes full speed
    Monitors turn off and every system fan goes full speed: Hello! I'm typing this as quickly as possible so I can get this up in time before my pc dies again. For no specific reason, my custom-built computer will just shut off the monitors and then every fan goes beserk. This happens during no specific task. Whether it be...
