Windows 10: Possible problem with charging port
Discus and support Possible problem with charging port in Windows 10 Gaming to solve the problem; A bit of initial information: whenever I disconnect or plug in my laptop's charging cable, I get a little "Brightness" popup at the top of my screen,... Discussion in 'Windows 10 Gaming' started by OrrUzan-Tidhar, Nov 26, 2021.
Possible problem with charging port - Similar Threads - Possible problem charging
Charge my laptop without the charging port.
in Windows 10 GamingCharge my laptop without the charging port.: So my charging port just broke, and it'll take many months that I don't have to fix it. I have critical files I need to save, then I'll repair them later. My laptop's at 0 percent, and I need to have a charging source that isn't from the charging port. Is there a way to... -
in Windows 10 Software and AppsCharge my laptop without the charging port.: So my charging port just broke, and it'll take many months that I don't have to fix it. I have critical files I need to save, then I'll repair them later. My laptop's at 0 percent, and I need to have a charging source that isn't from the charging port. Is there a way to... -
in Windows 10 Installation and UpgradeCharge my laptop without the charging port.: So my charging port just broke, and it'll take many months that I don't have to fix it. I have critical files I need to save, then I'll repair them later. My laptop's at 0 percent, and I need to have a charging source that isn't from the charging port. Is there a way to... -
how do i not allow the usb port not the charging port to charge devices
in Windows 10 Software and Appshow do i not allow the usb port not the charging port to charge devices: ok idk but it charges for no reason https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-not-allow-the-usb-port-not-the-charging/34354a2a-3c88-4c04-9f2e-8c6ec55cdfc9 -
in Windows 10 Gaminghow do i not allow the usb port not the charging port to charge devices: ok idk but it charges for no reason https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-not-allow-the-usb-port-not-the-charging/34354a2a-3c88-4c04-9f2e-8c6ec55cdfc9 -
in Windows 10 Software and AppsPossible problem with charging port: A bit of initial information: whenever I disconnect or plug in my laptop's charging cable, I get a little "Brightness" popup at the top of my screen, like I would get if I was changing the brightness manually. Now, when I'm using my laptop normally, it appears fine. But when... -
in Windows 10 Drivers and HardwarePossible problem with charging port: A bit of initial information: whenever I disconnect or plug in my laptop's charging cable, I get a little "Brightness" popup at the top of my screen, like I would get if I was changing the brightness manually. Now, when I'm using my laptop normally, it appears fine. But when... -
Charging with usb type c port
in Windows 10 Drivers and HardwareCharging with usb type c port: I'm trying to find out if it is possible to charge my vivobook S532F S15 using the usb type c port,I have the the power cable an the PD wall adapter. If so what worked for others? please list any software or hardware you think i might be missing.. thanks for your response..... -
possible unauthorized charge by microsoft
in AntiVirus, Firewalls and System Securitypossible unauthorized charge by microsoft: I received a charge on my credit card from Microsoft and have no idea why. Would like to speak to someone regarding this charge https://answers.microsoft.com/en-us/windows/forum/all/possible-unauthorized-charge-by-microsoft/29562a0f-78bb-4768-84bc-6df78d62d4f4
