Windows 10: Possible solution to fix the problem of my laptops' speakers?
Discus and support Possible solution to fix the problem of my laptops' speakers? in Windows 10 Software and Apps to solve the problem; I just want to ask if there is a possible solution to fix the problem of my laptop's speakers? The problem is, the speakers' volume are automatically... Discussion in 'Windows 10 Software and Apps' started by mayyyyyeah, Feb 28, 2024.
Possible solution to fix the problem of my laptops' speakers? - Similar Threads - Possible solution fix
in Windows 10 GamingPossible solution to fix the problem of my laptops' speakers?: I just want to ask if there is a possible solution to fix the problem of my laptop's speakers? The problem is, the speakers' volume are automatically going up and down. This laptop was just turned 1 year last month.... -
in Windows 10 Drivers and HardwarePossible solution to fix the problem of my laptops' speakers?: I just want to ask if there is a possible solution to fix the problem of my laptop's speakers? The problem is, the speakers' volume are automatically going up and down. This laptop was just turned 1 year last month.... -
How to fix problem with my speakers
in Windows 10 Drivers and HardwareHow to fix problem with my speakers: I have bought so white shark external speakers for my pc. My problem with them is that when i connect them to my pc i hear a hissing and a low pitch sound. That doesn’t happen when i connect them to my laptop. I think that the noise is being created because my pc power output... -
in Windows 10 GamingHow to fix problem with my speakers: I have bought so white shark external speakers for my pc. My problem with them is that when i connect them to my pc i hear a hissing and a low pitch sound. That doesn’t happen when i connect them to my laptop. I think that the noise is being created because my pc power output... -
in Windows 10 Software and AppsHow to fix problem with my speakers: I have bought so white shark external speakers for my pc. My problem with them is that when i connect them to my pc i hear a hissing and a low pitch sound. That doesn’t happen when i connect them to my laptop. I think that the noise is being created because my pc power output... -
USB Speaker wont work on a laptop solution
in Windows 10 Drivers and HardwareUSB Speaker wont work on a laptop solution: Plug the speaker in. Go to Speakers in System Settings. Disable your laptop speaker. Enable your USB speaker. When you unplug your USB speaker your laptop will default to the laptop speaker. If the USB speaker does not work when you plug it in again, go and disable your... -
Laptop speaker problem
in Windows 10 GamingLaptop speaker problem: First time i use microphone splitter its going smooth, suddenly my laptop creat loud sound in speakers. then I will disconnect the microphone splitter. then shut down my laptop! next day i switch on the laptop its creat same sound until When connect a microphone splitter in... -
in Windows 10 Software and AppsLaptop speaker problem: First time i use microphone splitter its going smooth, suddenly my laptop creat loud sound in speakers. then I will disconnect the microphone splitter. then shut down my laptop! next day i switch on the laptop its creat same sound until When connect a microphone splitter in... -
in Windows 10 Drivers and HardwareLaptop speaker problem: First time i use microphone splitter its going smooth, suddenly my laptop creat loud sound in speakers. then I will disconnect the microphone splitter. then shut down my laptop! next day i switch on the laptop its creat same sound until When connect a microphone splitter in...
