Windows 10: Power Plans problem
Discus and support Power Plans problem in Windows 10 Gaming to solve the problem; Ok, I'm just gonna get straight to the point. my computer is currently being an absolute B****. I was trying to change my power plan so I could have... Discussion in 'Windows 10 Gaming' started by Just a Weird Bird, Sep 17, 2024.
Power Plans problem
Power Plans problem - Similar Threads - Power Plans problem
Power plans
in Windows 10 Software and AppsPower plans: I tried all different solutions but nothing worked.I downloaded the pow files and nothing worked.I tried these codes:powercfg -duplicatescheme 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635cpowercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61powercfg -duplicatescheme... -
Power Plans
in Windows 10 Ask InsiderPower Plans: I updated my laptop to windows 10 2004 version and all my powerplans are missing. Please help submitted by /u/Caratecat [link] [comments] https://www.reddit.com/r/Windows10/comments/idb06t/power_plans/ -
power plan
in Windows 10 BSOD Crashes and Debuggingpower plan: pls. help to set my window power plan to high performance level, since computer is running slow and always got jammed https://answers.microsoft.com/en-us/windows/forum/all/power-plan/350c8da4-a351-430a-bd97-62c8ee82c948 -
Power Plans
in Windows 10 BSOD Crashes and DebuggingPower Plans: I've noticed that my fan is constantly running on high lately even when I have no apps or programs open. I went into the battery setting in order to change my power plan and there is only balanced. What's going on and is there another way to fix this issue?... -
Power Plan
in Windows 10 Performance & MaintenancePower Plan: My power plan only has the balanced one and I can't figure out how to get the high performance one. I went into create a power plan but it wasn't there also. Any way I can get the high performance plan?... -
Power Plans
in Windows 10 Performance & MaintenancePower Plans: I recently did a Fresh Start on my HP laptop as I was having issues with Windows Defender and my computer was running slow despite my best efforts to fix it. The install solved the problems I was having with Windows Defender and speed but I have been having issues with the... -
Power Plan
in Windows 10 Performance & MaintenancePower Plan: Why isn't my power plan available? I attemted to increase the time before the PC sleeps, but it seems to default to 10 minutes. https://answers.microsoft.com/en-us/windows/forum/all/power-plan/f2cab0f8-1715-4975-bc19-bfe1a3b62db5 -
Problem with power plans
in Windows 10 Performance & MaintenanceProblem with power plans: When I plug in my computer on battery, it always set to default using "Power4Gear High Performance". Since I don't want to use it, I deleted it and chose "High performance" instead. But later on, when I plug in my computer on battery again, the "Power4Gear High Performance"... -
Problem with power plans not showing at all
in Windows 10 SupportProblem with power plans not showing at all: Hi. Had a bad computer day and did a windows 10 reset. After the reset and some updates, when I go to control panel/system and security/power options, I see this: [img] It does not show the balanced/recommended plan I'm on and should normally show. If I click on...
