Windows 10: Power setting keep changing by itself
Discus and support Power setting keep changing by itself in Windows 10 BSOD Crashes and Debugging to solve the problem; Power settings change randomly to "Balanced" from high performance. I can't run my photo editing software on balanced power. Is there a solution?... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by JonathanChase, Mar 15, 2020.
Power setting keep changing by itself - Similar Threads - Power setting keep
PC keeps crashing/powering itself on at random
in Windows 10 BSOD Crashes and DebuggingPC keeps crashing/powering itself on at random: Hello! I've been having an issue recently with my computer shutting down while playing Genshin Impact, I'm not sure if the game is causing it as I haven't used my PC for anything else in the past few months. I have had a couple power surges while my computer was not plugged... -
Why's my brightness level and power plan setting keep changing by itself?
in Windows 10 CustomizationWhy's my brightness level and power plan setting keep changing by itself?: My laptop is MSI GF75 Thin 10SDRi7 10750H 2.6 GHzGTX 1660 Ti 6 GB VRAM16 GB Dual Channel RAMWindows 10 Home Single Language Version 20H2 OS Build 19042.985First of all, I apologize for my poor English skill, it's not my native language and learns it by self-taught so I hope... -
Windows 10 sleep and power settings keep changing
in Windows 10 Performance & MaintenanceWindows 10 sleep and power settings keep changing: Have a rather strange one here that I've been scratching my head on. We run Dell laptops at our job and I keep running into issues with sleep and power settings that don't stay after I make a change. Here is an example: Under Sleep & Power Settings for Sleep, I have the... -
Camera setting changing by itself
in AntiVirus, Firewalls and System SecurityCamera setting changing by itself: Hi - While using Zoom, the camera and microphone privacy settings keep reversing themselves. I go back and turn on the permissions for apps to use them, and then they go off a few minutes later - when I check the privacy settings, the permissions have been turned off. This... -
DNS server keeps changing itself
in Windows 10 Ask InsiderDNS server keeps changing itself: I used to have my DNS server set to 8.8.8.8 / 8.8.4.4 but in order to access a shared drive at work, I have to set it to automatic. Problem is, every time I bring my laptop into work, it's changed itself back to the Google DNS and I have to manually change it back every day.... -
Power options change by itself
in Windows 10 SupportPower options change by itself: I always change my power options from windows high performance to my custom power options every time i turn on my laptop and today i just left and lock my computer for about 2 minutes when i go back i notice the power options change by itself to high performance. At first i... -
Screen Resolution Keeps Changing Itself
in Windows 10 CustomizationScreen Resolution Keeps Changing Itself: My default (and recommended) screen resolution is 1366 x 968. This used to be fine. Now, very frequently, my laptop restarts (or wakes up from sleep) with a resolution of 1024 x 768. Windows Display Settings shows the resolution grayed out, so I can't change it. When I... -
Accent color keeps changing by itself
in Windows 10 CustomizationAccent color keeps changing by itself: I am experiencing a very strange issue with my color, ever since the November update it keeps changing on its own. It happens after every reboot, and after about 24 hours of being on, the color changes to this ugly pumpkin orange. At first I thought they just changed it when... -
Something Keeps Changing My Power Setting
in Windows 10 SupportSomething Keeps Changing My Power Setting: I have 4 Windows 10 machines at home, and one of them is showing the infamous "going to sleep" problem. That PC goes into sleep after about 15 seconds of inactivity. -If I reset the power setting and create a new power setting (e.g., sleep after 2 hours), the PC works...
