Windows 10: Power usage and excessive fan kicking in when running off battery
Discus and support Power usage and excessive fan kicking in when running off battery in Windows 10 BSOD Crashes and Debugging to solve the problem; Background ** For decades from the mid 70s to the late 90s I worked in the IT industry and for a Good time specialised on Operating Systems from... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Jerrym0, Jun 3, 2020.
Power usage and excessive fan kicking in when running off battery - Similar Threads - Power usage excessive
Excessive memory usage
in Windows 10 GamingExcessive memory usage: How can Windows use so much memory and not have a way to clean it? When I installed it, the system didn't take up that much, I left the SDD only for the system and the HD for my programs, today I opened a guide on the Microsoft website to clean the C: disk, but there are... -
in Windows 10 Software and AppsExcessive memory usage: How can Windows use so much memory and not have a way to clean it? When I installed it, the system didn't take up that much, I left the SDD only for the system and the HD for my programs, today I opened a guide on the Microsoft website to clean the C: disk, but there are... -
Fan running when display turns off
in Windows 10 Ask InsiderFan running when display turns off: This specifically happens when I leave my laptop open and it locks itself automatically. The display is off but some resource usage is very high because the fans start spinning at very high speeds. If I open task manager to check what it is, things just go back to normal and... -
kicked off
in Windows 10 Software and Appskicked off: I get kicked Minecraft every few minutes. Sometimes it says it's disconnected from server, but most of the time it just shuts down. https://answers.microsoft.com/en-us/windows/forum/all/kicked-off/21bc9ef3-791d-4f5a-adb7-1d8280938fe9 -
Windows Upgrade causing excess fan usage?
in Windows 10 Installation and UpgradeWindows Upgrade causing excess fan usage?: I have 2 Dell Latitude 3379 laptops. 1 of them was running Windows 2004 before it was released as it was part of the insider program at the time. One thing I noticed in it was that the fan was almost always on and working at considerable speed even though the temperatures... -
Fans running even when CPU usage is 2-5%
in Windows 10 Installation and UpgradeFans running even when CPU usage is 2-5%: For some weird reason my fans are running when the CPU usage is low! This doesnt happen outside of windows so it has to be a bug! I think it started happening after updating to Windows 10 2004!... -
HP 15-dy1038nr fans always run high when plugged into power, not when on battery
in Windows 10 Ask InsiderHP 15-dy1038nr fans always run high when plugged into power, not when on battery: [ATTACH] submitted by /u/thegeekpea [link] [comments] https://www.reddit.com/r/Windows10/comments/gmoh3x/hp_15dy1038nr_fans_always_run_high_when_plugged/ -
Cooling Fan Excessive running
in Windows 10 BSOD Crashes and DebuggingCooling Fan Excessive running: Hi, after my HP 250 Notebook (running Windows 10) received and instated the latest batch of Windows updates my cpu cooling fan begins to run as soon as I boot up. Are there any reported fan issues with the latest updates? It is really annoying now...……..... -
BATTERY excessive battery consumption
in Windows 10 Drivers and HardwareBATTERY excessive battery consumption: Hello, in first I am sorry for my bad english. In second, I installed w10 yesterday and today I notice an excessive battery consuption, because with the 100% battery charge and without usage, after 38 minutes the battery charge go down to 74% and I do not know why. In w8.1 I...
