Windows 10: Printer driver problems and problems with printer Set up.
Discus and support Printer driver problems and problems with printer Set up. in Windows 10 Installation and Upgrade to solve the problem; Hi I have a Canon G3510 wireless printer and used it to print from a Lenovo desktop. But to get it to print I first had to print something off the... Discussion in 'Windows 10 Installation and Upgrade' started by Oswald Druss, Jul 12, 2020.
  1. Printer driver problems and problems with printer Set up.
    Hi
    I have a Canon G3510 wireless printer and used it to print from a Lenovo desktop. But to get it to print I first had to print something off the internet before it would print a word document each day.
    It did work up to a couple of weeks ago when then was a couple of windows updates and now won't print. I contacted Canon who said to uninstall and reinstall the drivers.
    I have done this a couple of time in the last 2 days but to no joy. When I run trouble shooter I keep getting the message “Operation could not be completed error 0x000007d1, The specified driver is invalid”?
    I have noted similar questions from other but cannot get it to print. I also have a laptop and installed the print driver on that and it worked staright away but not on the desktop?
    Any advice?
    Thanks
  2. Firebeast Win User
    Mac OSX USB printer problem
    OK i just bought the Canon IP4500 usb printer and installed it on the mac following hte instructions to the letter.
    No printer is found and i cannot add it in the Printer list, cause theres no option for USB printer installation, only Appletalk, Bluetooth, and Windows Printing.
    I have downloaded the latest drivers etc... but no luck *Bang Head :banghead:
    As it is i dont like macs but now with a simple thing as this i dislike them even more.
    Last resort is trying installing the printer on a Vista pc and see if it works, if it does then the mac is up to shit, if it does not install then the printer is up to shit.
    Anyone had a similar problem maybe and how did you overcome it?
    Firebeast, Jul 12, 2020
  3. blkhogan Win User
    Printer problems
    This is probably an easy fix, I just cant seem to locate it myself. I have a printer hooked up to one of my rigs on my network. I have no problems with 4 out of the 5 on my network printing remotely. The one that is not playing nice is my wifes laptop. All of the rigs that work are all Win 7 ultimate. The one thats not happy is running stupid Vista Home. I loaded the drivers for the specific printer (cannon dc320 copier/printer), but it will not print. Is there anything that I need to do specifically to Vista to allow remote or network printing? It see's the printer and everything... it just no workie.
    blkhogan, Jul 12, 2020
  4. Printer driver problems and problems with printer Set up.
    epson printer problems
    H RCoon I done the wifi setup on the printer and the printer will print out a test sheet but when I try to print from the pc the printer page just sits there with 0 of 0 printing, when I go into printers and devices there is an exclamation mark on the printer I double clicked the printer icon and now there is a tick on it but it still wont print and when I run the troubleshooter attached to the printer it says restarting the spooler device. I never had this problem before usually once I use the disc it works with no problem. how do I check to see if the printer is connected to the router. I just tried it from my phone and it is printing with no problems.
    cookiemonster, Jul 12, 2020
  1. Printer driver problems and problems with printer Set up. - Similar Threads - Printer driver problems
  2. Printer driver problems
    Printer driver problems: Windows updated the printer driver on my laptop on 8th June 2022. Since then all printing jobs on my HP printer have come out blurred with some lines in italics. All diagnostic tests have been tried out on the printer with no result. HP have told me that it is a problem with...
  3. Printer driver problems
  5. updating printer driver problem
    updating printer driver problem: I have an older HP printer which I really like; I have updated the driver a few times previously with no problems. The last computer I got had Win10 installed & the printer worked ok until the last year or so when it would more & more often not print a page or selection on a...
  6. Problem in installing printer driver
    Problem in installing printer driver: HiI have a problem in installing my printer program after I click on it will start extracting and nothing happening after it.I tried everything and nothing happened...
  7. HP Printer Driver Problem
    HP Printer Driver Problem: Downloaded the printer driver for HP LaserJet Pro 400 series, M451dn. Attempted to install, restarted, unplugged, restarted again and continue to get the fatal error message unable to install. Works fine on other computers without Windows 10 Pro....
  8. Printer driver problems and problems with printer Set up.
    Printer driver problems and problems with printer Set up.: Hi I have a Canon G3510 wireless printer and used it to print from a Lenovo desktop. But to get it to print I first had to print something off the internet before it would print a word document each day. It did work up to a couple of weeks ago when then was a couple of...
  9. Printer driver installing problem
    Printer driver installing problem: I'm trying to install Sharp AR-206 network printer. Driver will be found from Windows Update, but Windows won't install it . I just get notice "Printer driver not installed". [ATTACH] With my other computers (also Win10Pro) I don't have this problem. Is there any way to...
  10. Problem with HP Printer Driver
    Problem with HP Printer Driver: Driver Program opens fine, goto select software wanna install, stops dead there, click on to Continue, nothing happens, even tried another mouse no luck, WIndows 10 Pro 64bit Creators 15063.296, Logitech Mouse, G600 8.92.67 driver for that. Printer is Deskjet F4480 84322
