Windows 10: Problem connecting Surface Pro 4 to Galaxy s7
Discus and support Problem connecting Surface Pro 4 to Galaxy s7 in Windows 10 Drivers and Hardware to solve the problem; When I connect S7 to surface pro I can see all my files on the phone and the sd card. I can create a new folder on the SD card but when I go to rename... Discussion in 'Windows 10 Drivers and Hardware' started by gunmanivan, Jul 4, 2016.
Problem connecting Surface Pro 4 to Galaxy s7 - Similar Threads - Problem connecting Surface
Surface Pro 4 - Midi Connectivity
in Windows 10 GamingSurface Pro 4 - Midi Connectivity: Surface Pro 4 with clean install & won't recognize midi when plugged in, yet it powers up the devices Arturia MiniLab II nor Zoom R24.I found a Windows driver issue on their website which recommended taking out the Intel Smart Sound Technology driver. This doesn't do it.I've... -
in Windows 10 Software and AppsSurface Pro 4 - Midi Connectivity: Surface Pro 4 with clean install & won't recognize midi when plugged in, yet it powers up the devices Arturia MiniLab II nor Zoom R24.I found a Windows driver issue on their website which recommended taking out the Intel Smart Sound Technology driver. This doesn't do it.I've... -
in Windows 10 Drivers and HardwareSurface Pro 4 - Midi Connectivity: Surface Pro 4 with clean install & won't recognize midi when plugged in, yet it powers up the devices Arturia MiniLab II nor Zoom R24.I found a Windows driver issue on their website which recommended taking out the Intel Smart Sound Technology driver. This doesn't do it.I've... -
Surface Pro 4 USB not connecting to scanner
in Windows 10 Drivers and HardwareSurface Pro 4 USB not connecting to scanner: Trying to get a small check scanner connected to a surface pro. When I connect the scanner, the USB doesnt seem to recognize the device. When I plug in a cell phone, the USB recognizes the phone. The scanner is working correcdtly as I plug it into the PC tower next to the... -
Surface Pro connection problem
in Windows 10 Installation and UpgradeSurface Pro connection problem: My surface Pro is not connecting to the internet or showing any connections. Diagnostic check states "Possible problem with wi-fi adaptor" which the fix did not resolve. Thanks in anticipation.... -
Samsung Galaxy S7 Cannot Connect to my PC.
in Windows 10 Ask InsiderSamsung Galaxy S7 Cannot Connect to my PC.: I am trying to connect my Samsung Galaxy S7 to my Windows 10 Pro-64 Bit desktop PC, but it isn't showing up in file explorer. It is plugged to the computer via a USB hub, however I don't think that is the problem as my phone still charges. I have my phone's USB settings set... -
connecting samsung galaxy s7 hotspot to windows
in Windows 10 Drivers and Hardwareconnecting samsung galaxy s7 hotspot to windows: my dell latitudeE4310 shows the samsung hotspot is detected..but..i can not connect to it......there is no box appearing to enter the hotspot pin. how can i connect the s7 hotspot to this laptop? tx... -
Connecting keyboard to surface 4 pro
in Windows 10 Drivers and HardwareConnecting keyboard to surface 4 pro: I cannot get my keyboard to connect anymore to my surface pro 4. I re-set to default but this didn't help either https://answers.microsoft.com/en-us/windows/forum/all/connecting-keyboard-to-surface-4-pro/b51b8035-a4b2-4f33-9640-17bf07822dc9 -
Connecting dual monitors to Surface Pro 4
in Windows 10 Drivers and HardwareConnecting dual monitors to Surface Pro 4: Are there any good tutorials out there on how to do this? Thanks, Nate https://answers.microsoft.com/en-us/windows/forum/all/connecting-dual-monitors-to-surface-pro-4/d0aea477-10ba-479f-8129-982da2d79ce1
