Windows 10: Problem connecting to wireless. Adapter is corrupt
Discus and support Problem connecting to wireless. Adapter is corrupt in Windows 10 Drivers and Hardware to solve the problem; I have an Acer Aspire F5-572 and it doesn't show me any networks floating around. I have had to connect it to the Ethernet cable which is in a really... Discussion in 'Windows 10 Drivers and Hardware' started by SannaHickman, Sep 3, 2019.
Problem connecting to wireless. Adapter is corrupt - Similar Threads - Problem connecting wireless
Wireless adapter problem
in Windows 10 GamingWireless adapter problem: My wireless adapter at random times fails randomly. The ping will jump from 30 ms to 4 seconds or even time out when sending the packets to the router via ping. It happened after the Windows update. Before that he never had this problem. Is there any way to fix this problem?... -
in Windows 10 Software and AppsWireless adapter problem: My wireless adapter at random times fails randomly. The ping will jump from 30 ms to 4 seconds or even time out when sending the packets to the router via ping. It happened after the Windows update. Before that he never had this problem. Is there any way to fix this problem?... -
Wireless adapter problems
in Windows 10 GamingWireless adapter problems: I accidentally deleted the wireless adapter on my PC. How do I reinstall it? I tried a system restore but they keep failing. https://answers.microsoft.com/en-us/windows/forum/all/wireless-adapter-problems/91ce3847-8964-41a5-93f8-557cea221ca1 -
in Windows 10 Software and AppsWireless adapter problems: I accidentally deleted the wireless adapter on my PC. How do I reinstall it? I tried a system restore but they keep failing. https://answers.microsoft.com/en-us/windows/forum/all/wireless-adapter-problems/91ce3847-8964-41a5-93f8-557cea221ca1 -
wireless adapter problem
in Windows 10 Drivers and Hardwarewireless adapter problem: My wireless adapter randomly Happened after a Windows update. Before that he never had this problem. Is there any way to fix this problem? https://answers.microsoft.com/en-us/windows/forum/all/wireless-adapter-problem/4ec9e317-3bd7-44e7-9934-be89bcadf04e -
Wireless internet connection problems may be a wireless network adapter problem
in Windows 10 Network and SharingWireless internet connection problems may be a wireless network adapter problem: For several weeks I have been having problems with my wireless internet connection dropping out every few days. I always use Troubleshoot Problems and the result is usually a Network Adapter Problem. First if I disconnected and reconnected a few times it would sort the... -
in Windows 10 Drivers and Hardwarewireless adapter problem: My wireless adapter on random time and day it randomly bugs out the windows diagnostic found theres a problem with the adapter or the access point so it resets which fixes it. resetting it myself works also. The ping will jump from 30ms to 4 secs or even timing out on... -
problems connecting Wireless display adapter
in Windows 10 Drivers and Hardwareproblems connecting Wireless display adapter: The problem is that I cant connect my PC to my TV using the Microsoft wireless display adapter. it works perfectly with my android phone but no matter what I tried it wont connect to the PC. It always show like its connecting (also in the TV screen) but then it dies after a... -
Wireless Adapter Not Connected.
in Windows 10 Network and SharingWireless Adapter Not Connected.: Hey guys, so I'm on my MSI laptop, turned it on today and it basically told me I have no wireless adapter. I'm going to attach screenshots of everything I can to try and help with this, any help would be appreciated. Killer Wireless Wifi Adapter showing up but hidden:...
corrupted wireless adapter files
