Windows 10: problem in my other devices section in my bluetooth settings.
Discus and support problem in my other devices section in my bluetooth settings. in Windows 10 Customization to solve the problem; how to fix this problem.it only shows the remove device option and not the connect option. it tried to fix it a lot but it did not fix. this is... Discussion in 'Windows 10 Customization' started by ARNAV YADAV, Sep 23, 2022.
problem in my other devices section in my bluetooth settings. - Similar Threads - problem devices section
I dont see my bluetooth switch in my bluetooth and other devices section, any help?
in Windows 10 GamingI dont see my bluetooth switch in my bluetooth and other devices section, any help?: I cant seem to seen my bluetooth option as you can see here. https://answers.microsoft.com/en-us/windows/forum/all/i-dont-see-my-bluetooth-switch-in-my-bluetooth-and/a8e97fb9-b737-4d80-90fa-a62c6dcf2cb8 -
in Windows 10 Software and AppsI dont see my bluetooth switch in my bluetooth and other devices section, any help?: I cant seem to seen my bluetooth option as you can see here. https://answers.microsoft.com/en-us/windows/forum/all/i-dont-see-my-bluetooth-switch-in-my-bluetooth-and/a8e97fb9-b737-4d80-90fa-a62c6dcf2cb8 -
in Windows 10 CustomizationI dont see my bluetooth switch in my bluetooth and other devices section, any help?: I cant seem to seen my bluetooth option as you can see here. https://answers.microsoft.com/en-us/windows/forum/all/i-dont-see-my-bluetooth-switch-in-my-bluetooth-and/a8e97fb9-b737-4d80-90fa-a62c6dcf2cb8 -
in Windows 10 Gamingproblem in my other devices section in my bluetooth settings.: how to fix this problem.it only shows the remove device option and not the connect option. it tried to fix it a lot but it did not fix. this is happening with me since last 5 months. please help!!!... -
in Windows 10 Software and Appsproblem in my other devices section in my bluetooth settings.: how to fix this problem.it only shows the remove device option and not the connect option. it tried to fix it a lot but it did not fix. this is happening with me since last 5 months. please help!!!... -
Found random Bluetooth devices in "Devices and other devices" section
in Windows 10 Ask InsiderFound random Bluetooth devices in "Devices and other devices" section: [ATTACH] Today while I was pairing my phone to my PC I saw these Microsoft devices with random string of letters and numbers already paired. Should I be worried about them or leave them as they are?... -
The Add Bluetooth & other devices button in Setting->Bluetooth & other devices not responsed
in Windows 10 Drivers and HardwareThe Add Bluetooth & other devices button in Setting->Bluetooth & other devices not responsed: In Setting->Bluetooth & other devices, when press the "+" button to Add Bluetooth or other device, nothing responded. I still can add through the "Devices and printers". [ATTACH]... -
Can't add a second Bluetooth Earbud Device to my Settings - Devices - Bluetooth & other...
in Windows 10 Drivers and HardwareCan't add a second Bluetooth Earbud Device to my Settings - Devices - Bluetooth & other...: Greetings, I'm having trouble setting up a second set of Bluetooth Earbuds in Settings so I can use them when my first pair of earbuds run low on Battery. I already have a set of BlueWow A5L & BlueWow A5R listed in the Audio section under Bluetooth & other devices. I also... -
Settings->Bluetooth and other devices : BCM20702A0 (?)
in Windows 10 Drivers and HardwareSettings->Bluetooth and other devices : BCM20702A0 (?): At 'Settings'-> 'Bluetooth & Other devices' I see BCM20702A0 listed below Other devices. Don't know where it stands for, what it is used for. I am not sure whether at all this option (Bluetooth) should be enabled at all: apart from my Android tablet I have no...
