Windows 10: Problem number 2: BSOD - Memory Management - Unknown Module. Help?
Discus and support Problem number 2: BSOD - Memory Management - Unknown Module. Help? in Windows 10 Software and Apps to solve the problem; Hi, recently I posted a question asking for help for a memory management BSOD issue. The thought cause was a module or program called Svchost.exe. I... Discussion in 'Windows 10 Software and Apps' started by JMac19_687, Dec 12, 2024.
  1. Problem number 2: BSOD - Memory Management - Unknown Module. Help?
    Hi, recently I posted a question asking for help for a memory management BSOD issue. The thought cause was a module or program called Svchost.exe. I deleted that program and ran into another BSOD while the computer woke up from a short sleep.Just to let you know, I have changed my GPU, and my RAM, and all my drives have been tested by SeaTools as healthy above 90%.Here is the minidump: https://docs.google.com/document/d/19wfbyMJwZJceIP0ktQYhi31MUfoZuGdKyD3_RxQ_WF0/edit?usp=sharingHere is a sleep study: https://drive.google.com/file/d/1-lKOgFMhZe9rQV__zj5HVGkgJ8Ljn4B_/view?usp=sharingThanks in
  2. Janschi Win User
    BSOD "Memory Management" Stop 0x0000001A
    Thanks Rohit,
    The method of deleting temp-files brings me into the windows explorer program, showing the list. But when attempting to delete the list after "Ctrl-A" the BSOD is there.
    No disk-related actions are possible.
    The memory modules are OK.
    Please help!
    Janschi, Dec 12, 2024
  3. IRQ memory BSODS, device manager, memory range?
    The only time I've seen that type of BSOD for myself is when I fried the PCI-e slots on my Striker 2 board... There wasn't anything that I could do, try and rma and go on.. I would suggest the steps that MilkyWay has said.. But, if you really don't know much about Bios's... I wouldn't play with Irq's... That can mess up everything on your board. USB, ethernet, ram, chip... But, that's just me on playing with irq's... To much of a hassle IMHO..
    Cold Storm, Dec 12, 2024
  4. Problem number 2: BSOD - Memory Management - Unknown Module. Help?
    BSOD Memory management, PFN list corrupt, IRQL NOT LESS OR EQUAL
    Hi I'm not sure what the problem is, I've tried to find the problem on my own but I couldn't.
    I have gone down the things on what to do in a previous thread that I found but to no avail. Redirecting
    As
    the title suggests I am suffering from BSOD with the following error codes: Memory management, PFN list corrupt, IRQL NOT LESS OR EQUAL.
    When I started the driver verifier it kept crashing as soon as I started windows, but it doesn't show the xxxx.sys like it did for the person in the thread.
    But I do have the dmp files associated with the crash:
    051623-8546-01.dmp
    051423-80921-01.dmp
    051423-76765-01.dmp
    Any help or suggestions is appreciated,
    Thanks.
    Jermain Chen, Dec 12, 2024
  1. Problem number 2: BSOD - Memory Management - Unknown Module. Help? - Similar Threads - Problem number BSOD
  2. Problem number 2: BSOD - Memory Management - Unknown Module. Help?
    Problem number 2: BSOD - Memory Management - Unknown Module. Help?: Hi, recently I posted a question asking for help for a memory management BSOD issue. The thought cause was a module or program called Svchost.exe. I deleted that program and ran into another BSOD while the computer woke up from a short sleep.Just to let you know, I have...
  3. BSOD Memory Management Please help
    BSOD Memory Management Please help: Hey,For the past few years, I have been getting this Memory Management blue screen error. I get them mostly while playing games or loading into games. I have bought new RAM and a complete fresh installation of Windows. It's getting to the point where I even get the BSOD in...
  4. Memory Management BSOD problem
    Memory Management BSOD problem: Greetings!I've got a laptop, the model is Acer Aspire 3 A315-32, Windows 11 runs on this device. Occasionally, the laptop gets memory_management blue screen of death for no apparent reason. I've already tried the Memory Diagnostics Tool to test the memory, but the memory just...
  5. Memory Management BSOD problem
  6. HELP BSOD memory management error
    HELP BSOD memory management error: I needed to update my Dell Latitude E6530 to something higher than windows 7 where it worked perfectly so that I could do exams. NOW I keep getting the BSOD memory management error and my computer shuts down. It has been suggested that I uninstall the video drives that...
  7. Please help: BSOD Memory Management
    Please help: BSOD Memory Management: Hi, With no changes to my hardware, I have started getting BSODs with stop code: MEMORY MANAGEMENT. I have checked the RAM with Memtest several times, which did not find errors. However, driver verifier did find some errors after running it Windows got stuck into boot...
  8. BSOD with new modules of memory
    BSOD with new modules of memory: Hello guys , good night! I came here cuz i really don't know exactly what to do pls help me =[] After acquire a new memory kit all equals so using all 4 modules of memory and updating the Windows, GPU, Chipset, BIOS i'm getting the BSOD =[, on eventviewer i get this...
  9. BSOD memory management error. Help.
    BSOD memory management error. Help.: Recently I'm getting random BSOD screens in a while with the memory management error. I searched the whole internet for a solution but can't find any. My ram is in good shape after the ram test. I don't know what to do to fix it. It's so annoying while I'm doing just casual...
  10. BSoD - Memory Management - Please Help
    BSoD - Memory Management - Please Help: It is happening every time I start up my computer. Windows loads, I see my desktop and then BSoD shows up with the Memory Management code. I can boot to Safe Mode without the BSoD showing up. My event viewer is showing the following errors before it re-booted: The Windows...
