Windows 10: PROBLEM: Right Click And File Explorer Not Working
Discus and support PROBLEM: Right Click And File Explorer Not Working in Windows 10 BSOD Crashes and Debugging to solve the problem; Ok, Let's Go Straight To The Point: Everytime I Press Right Click In The Desktop, I'm Greeted With An Spinning Circle, If I Do Nothing It Just Stay... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Slenderzito, May 12, 2021.
  1. PROBLEM: Right Click And File Explorer Not Working
    Ok, Let's Go Straight To The Point: Everytime I Press Right Click In The Desktop, I'm Greeted With An Spinning Circle, If I Do Nothing It Just Stay There, Spinning, If I Do Something It Blacks Out And Appears Again, And About File Explorer, If I Open Any Folder It Just Gives An Message "Working On This" And Never Loads, Can Someone Help Me With This?
  2. Ralph Sta Win User
    File explorer icon from taskbar dissappears while working on it
    To assist you with your concern, we suggest you pin the File Explorer from the Start Menu by following these steps:
    • Click the Start Menu.
    • Right-click File Explorer.
    • Choose Pin to taskbar.
    If you need further assistance, feel free to reply to this post.
    Ralph Sta, May 12, 2021
  3. File explorer
    Hi Mick,
    I am sorry to know that the File Explorer is not working on the Taskbar.
    I suggest you to right-click on it to unpin it from the task bar.
    Then search for File Explorer in Search. Then right-click on it to Pin it to Taskbar.
    If the issue persists, try the steps below.
    • Type CMD in Search. Right click on it to run as an administrator.
    • Type the following 4 commands at the Command prompt:
    dism /online /cleanup-image /restorehealth
    sfc /scannow
    powershell
    Get-AppXPackage -AllUsers |Where-Object {$_.InstallLocation -like "*SystemApps*"} | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
    • Close the CMD window.
    • Check to see if the issue is resolved. If not, restart the PC.
    Kalpana Shankarappa, May 12, 2021
  4. PROBLEM: Right Click And File Explorer Not Working
    File Explorer Search Not Working
    I am trying to search in File Explorer (Windows Explorer, My Computer) and it will not find anything. I can copy text from a name in the list and paste it in the search box and it still finds nothing. I have looked at the suggestions that have been posted and nothing I find that is relative to this works. Anyone have any suggestions? I am running Win 10 Pro on an I3 coustom desktop computer.
    Maestro2711, May 12, 2021
  1. PROBLEM: Right Click And File Explorer Not Working - Similar Threads - PROBLEM Right Click
  2. file Explorer on right click crashing
    file Explorer on right click crashing: When I right click explorer automatically restart and I cannot delete files, creating folders and much more and I don't know how to repair it https://answers.microsoft.com/en-us/windows/forum/all/file-explorer-on-right-click-crashing/5043c183-2eb0-4734-a753-ca7b47ccb6f9
  3. right click not working in file explorer
    right click not working in file explorer: hello,I am encountering with an issue in file explorer windows 10. I wanted to print some documents and when i right clicked in the folder. It just hanged, like when the cursor shows a blue round moving animation only. That happened and the file explorer froze. I cant even...
  4. right click not working in file explorer
  5. right click not working in file explorer
  6. Problem with Right-Clicking on Desktop and File Explorer
    Problem with Right-Clicking on Desktop and File Explorer: I'm having major issues with right clicking things on the desktop and with right clicking in file explorer. When I right click on both the desktop and in file explorer, I get the blue spinning circle and it never returns back to normal. The right clicking on desktop started...
  7. Problem with right clicking on file explorer in the taskbar
    Problem with right clicking on file explorer in the taskbar: Hello. I am having a weird problem. Sometimes when I right click on the file explorer icon in the taskbar nothing happens when other times I get the usual quick menu. It seems to be about a 75/25 split. I haven't changed anything and it only happens with file explorer....
  8. Right click hangs for File Explorer
    Right click hangs for File Explorer: I have an issue that just started, and I could use some help. I want to format a hard drive, but when I ues File Explorer and right click on it to do this, I just get " not responding" Can anyone help me to fix this please? Thank you...
  9. Left-Click and right-click not work after right-click on File Explorer (in task bar)
    Left-Click and right-click not work after right-click on File Explorer (in task bar): when I right-click on file explorer to try to open frequent or pinned folder, left-click or right-click on folder name are resulting in nothing happen but I can still pin or unpin folder normally....
  10. Right click not working in Explorer
    Right click not working in Explorer: Not sure when this issue came up, maybe a few days or longer, I just kept doing other things to get by. If on a webpage or desktop I can use the right click, but in explorer if I right click a folder it brings up the menu, then taskbar icons all flash, then quickly...
