Windows 10: pROBLEM WITH CAPS LOCK KEY ANd mouse.
Discus and support pROBLEM WITH CAPS LOCK KEY ANd mouse. in Windows 10 Drivers and Hardware to solve the problem; the caps lock key is nOT WORKINg properly;; it enGAGES ANd disenGAGES ON its own AS YOU CAN see. also, my cursor frequ?enTKY 'DISSAPEARS' OFF THE... Discussion in 'Windows 10 Drivers and Hardware' started by CharlotteDe, May 10, 2020.
pROBLEM WITH CAPS LOCK KEY ANd mouse. - Similar Threads - pROBLEM CAPS LOCK
Problem With Cap Locks Key
in Windows 10 GamingProblem With Cap Locks Key: I have been currently experiencing problems with the Cap Locks key on my laptop HP 255 G7 Notebook for maybe over a month or so and I really need help with fixing it. It started when out of nowhere my Cap Locks key would just turn on or off by itself like if someone was just... -
in Windows 10 Software and AppsProblem With Cap Locks Key: I have been currently experiencing problems with the Cap Locks key on my laptop HP 255 G7 Notebook for maybe over a month or so and I really need help with fixing it. It started when out of nowhere my Cap Locks key would just turn on or off by itself like if someone was just... -
in Windows 10 Drivers and HardwareProblem With Cap Locks Key: I have been currently experiencing problems with the Cap Locks key on my laptop HP 255 G7 Notebook for maybe over a month or so and I really need help with fixing it. It started when out of nowhere my Cap Locks key would just turn on or off by itself like if someone was just... -
caps lock key
in Windows 10 Software and Appscaps lock key: Hi, after win 11 pro update the visual mode of my caps lock and num lock keypad doesn't work, i tried everything again but it doesn't work. Please help me! https://answers.microsoft.com/en-us/windows/forum/all/caps-lock-key/9272a23b-a780-4442-abd3-c66017b299b6 -
caps lock key
in Windows 10 Gamingcaps lock key: Hi, after win 11 pro update the visual mode of my caps lock and num lock keypad doesn't work, i tried everything again but it doesn't work. Please help me! https://answers.microsoft.com/en-us/windows/forum/all/caps-lock-key/9272a23b-a780-4442-abd3-c66017b299b6 -
Problem in Caps Lock Key
in Windows 10 Drivers and HardwareProblem in Caps Lock Key: The Caps Lock key does not stay turned off. It turns on voluntarily and it makeS THINGS DIFFIULT TO TYPE. As yOU CAN SEE. This needs a SOLUtION. I have tried help at the MicroSOFT COMMUNITY BEFORE. Did everything the help TOLD VIA CHAT. Tried to switch to Shift key TO SWITCH... -
Problem with Caps Lock key
in Windows 10 Drivers and HardwareProblem with Caps Lock key: Hello I bought a wireless Logitech K800 Keyboard and I use Windows 10 Pro 64 bits 1) It seems the Caps lock does not work (and the Nums lock key neither ! Is the re a wa y to fix it ? 2) Contrary to the "old" keyboards, there is no visual indicator of the status of these... -
Caps Lock key
in Windows 10 Drivers and HardwareCaps Lock key: My caps lock key isn't working when pressed. It's a Laptop and I've attached an external keyboard and it doesn't work on there either. Things I've tried: 1 re-writing the registry for caps lock by forcing it off and then back on. 2 re-map the key to another key still... -
Caps Lock Key
in Windows 10 Drivers and HardwareCaps Lock Key: HI, my caps lock key on my laptop is acting strange. Sometimes it doesn't work at all. Sometimes it doesn't work in Word, but does on the internet, but I can't turn it off. I plugged in another keyboard into my laptop, and it still didn't work, so it's not a problem with the...
caps lock not working windows
