Windows 10: Problem with cursor jumping to upper left corner.
Discus and support Problem with cursor jumping to upper left corner. in Windows 10 Drivers and Hardware to solve the problem; How do I find "Disable internal pointing devices when external USB" on Windows 10?... Discussion in 'Windows 10 Drivers and Hardware' started by GeorgeNewsom, Sep 19, 2020.
Problem with cursor jumping to upper left corner. - Similar Threads - Problem cursor jumping
A small bar appears at the upper left corner
in Windows 10 Software and AppsA small bar appears at the upper left corner: I installed a new game on my laptop yesterday. Whenever I try to press a key when playing the game, I get this small bar that stops me from playing my game. There seems to be nothing attached to it and my taskbar doesn't show an app opening either. Any ideas?... -
UPPER LEFT CORNER FLOATING WINDOW
in Windows 10 CustomizationUPPER LEFT CORNER FLOATING WINDOW: How do you remove this thing showing on the upper left of my screen, I dont have any third party apps installed, no Rainmeter or whatnots. https://answers.microsoft.com/en-us/windows/forum/all/upper-left-corner-floating-window/c031330f-533b-4473-9577-b25ceca7a946 -
Extreme upper left corner of monitor
in Windows 10 CustomizationExtreme upper left corner of monitor: At the extreme upper left corner of the screen, there is a tiny white dot. When I put the mouse cursor on it, I get one of those spinning blue "waiting" circles... well, actually only a quarter of one of those as if the top and entire left part of the circle is outside the... -
pointer jumps to upper right corner
in Windows 10 Drivers and Hardwarepointer jumps to upper right corner: My computer is a Surface Book 3 running the latest version of Windows 10. The pointer just started jumping to the upper right corner of the screen. It happens with the Arc Mouse or with the touch pad. If I disconnect the screen from the keyboard the mouse work fine, no... -
Stop or reset Windows Media Player from jumping to upper left corner
in Windows 10 Software and AppsStop or reset Windows Media Player from jumping to upper left corner: When my screen goes to sleep, if Windows Media Player Library is open, it jumps up to the upper left hand of the screen. Never seen this on any of my PC's. It is an Intel Graphics card. Is there a way to prevent this or reset WMP to its default size and position? Thanks 153606 -
Cursor jumps to upper right hand corner
in Windows 10 Drivers and HardwareCursor jumps to upper right hand corner: I have a Toshiba laptop and use external, wireless keyboard and mouse with larger monitor. Occasionally, the cursor jumps to the upper right hand corner and I'm stuck; it easily corrects by opening and closing the laptop lid -albeit a minor burr but a burr. I've recently... -
Small Gray Rectangle in Upper Left Corner
in Windows 10 CustomizationSmall Gray Rectangle in Upper Left Corner: First of all, I am using a Surface Pro 3. This problem is weird because it only happens once in a while when my laptop goes to sleep (but not always), and it only goes away once I restart my computer. [IMG] I cannot use my desktop while it is there, and I can move the gray... -
Cursor jumping to top left corner.
in Windows 10 BSOD Crashes and DebuggingCursor jumping to top left corner.: I have an HP laptop model 16-ay191ms with Windows 10 build 17134.345 which I cannot use while unplugged. The PC has always had a problem with the cursor jumping to the top right of the screen at random times, but I thought I cured it. Today, while it was unplugged, the... -
Rectangular Box in Upper Left Corner
in Windows 10 SupportRectangular Box in Upper Left Corner: I believe I accidentally generated this rectangular (not square) box while I was learning about the Magnifier. This rectangular (7.5 cm X 4.3 cm) box causes whatever is located underneath it to be slightly whiter than it normally would be. Everything functions properly while...
