Windows 10: Problem with HD graphics card using display port
Discus and support Problem with HD graphics card using display port in Windows 10 Drivers and Hardware to solve the problem; I don't think that Build 10041 and my AMD gaphics driver are the best of friends. I have a 2550*1440 Viewsonic screen attached to an HD 5670... Discussion in 'Windows 10 Drivers and Hardware' started by machare, Mar 23, 2015.
Problem with HD graphics card using display port - Similar Threads - Problem graphics card
Outdated Intel HD graphics card!
in Windows 10 Drivers and HardwareOutdated Intel HD graphics card!: Hello! I have a serious problem with my intel graphics card, its 37 months out of date, I updated it via windows update but its still from 2017 and not recent. My computer is an intel Celeron N3060, if you guys can send me a updated graphics driver that would be extremely... -
How to change the graphics card used by display
in Windows 10 Drivers and HardwareHow to change the graphics card used by display: Hi, I am using a BENQ monitor as display from my laptop. However, it is connected to my NVIDIA GPU. How do I connect it to intel graphics like my first display laptop display. Thanks in advance!... -
Problem using my graphics card
in Windows 10 Ask InsiderProblem using my graphics card: (Sorry for the bad grammar) So i got a pc a while back but he seemed a bit slow when i play game and do other stuff which uses my graphics card so i checked why this was slow but then i figured out that i basically have 2 graphics card or it seems so because when i go to... -
Best 'Graphics Card to Buy and Current Display Problems.
in Windows 10 Graphic CardsBest 'Graphics Card to Buy and Current Display Problems.: I'm in the process of choosing parts for a new PC build. So far I have decided to buy an AMD 3900X and 64GB memory but cannot decide on a graphics card. I run 3 monitors that are all quite old and I want to upgrade the main one (currently a DELL U2711) to a 32" when I can... -
graphics card problem
in Windows 10 BSOD Crashes and Debugginggraphics card problem: One day I opened up fortnite it was like 9 fps so I opened device manager and my gpu the gt 840 m was reporting the infamous code 43 error of windows stopped this device because it has reported problems.The real problem is that I almost tried everything to fix it I removed... -
graphic card problem
in Windows 10 Drivers and Hardwaregraphic card problem: hi I had problem with my graphic card settings the graphic card working properly but in windows its not showing the graphic card in display setting and also in task manager [ATTACH] 2 to 3 days before this was showing graphic card geforge 710... -
Display port problem
in Windows 10 SupportDisplay port problem: Hi i have just changed my mobo, cpu and gpu from intel to amd, and a problem has followed over. When connecting my 3 monitors with display port it wont work. On my old setup it was the same thing , only way i could do it was to have 1 display port, 1 hdmi and one dvi. So to... -
Graphic Card problem
in Windows 10 Drivers and HardwareGraphic Card problem: My problem is that update my graphics card in a fairly old computer, approximately 2010, then the screen went black, when the screen returned to show images the resolution changed to 1024 x 768, (I must clarify that my resolution was the most high left in windows 10), and I... -
Graphic card problems
in Windows 10 Graphic CardsGraphic card problems: Bought a used Asus EN210 and when installed found the driver keeps freezing the pc (windows 10). I regularly get a popup telling me that is what is happening.... So I bought another card, a Zotac GT218 which does the same. It turns out both of these are basically Nvidia...
problems with graphics card when using display port
