Windows 10: Problem with login using hello picture and pin
Discus and support Problem with login using hello picture and pin in Windows Hello & Lockscreen to solve the problem; Something went wrong during a sign in and both the windows hello and pin login are shown as not available. They both worked earlier on my machine. Is... Discussion in 'Windows Hello & Lockscreen' started by StevenGordon2, Mar 6, 2020.
Problem with login using hello picture and pin - Similar Threads - Problem login using
Stuck in hello pin login loop
in Windows 10 GamingStuck in hello pin login loop: Im stuck in a loop where I cant login to my laptop.I enter my login details then it wants me to create a pin. I click next Then it says something went wrong, we werent able to set up your pin, you can try again or skip this step and try again later. I select try again with no... -
in Windows 10 Software and AppsStuck in hello pin login loop: Im stuck in a loop where I cant login to my laptop.I enter my login details then it wants me to create a pin. I click next Then it says something went wrong, we werent able to set up your pin, you can try again or skip this step and try again later. I select try again with no... -
Problem using Windows Hello PIN
in Windows Hello & LockscreenProblem using Windows Hello PIN: Hi I have just signed up to windows hello with a new pin. Now when I sign in I have to do It twice. One image is superimposed on another. My computer works eventually but this is annoying.[Original Title: windows hello]... -
Problem with unlocking my laptop by using hello pin
in Windows Hello & LockscreenProblem with unlocking my laptop by using hello pin: Recently i have changed my Microsoft Hello pin.After changing the pin i am unable to unlock my laptop by both hellopin and by password.•This what happens when i try to unblock my laptop with hellopin "Something happened and your PIN isn't available. Choose another sign in... -
Hello pin problem
in Windows Hello & LockscreenHello pin problem: Hi, I have a problem with the hello pin in my windows computer whenever I set my pin it always say ''something went wrong'' ''We weren't able to set up your PIN'' please help me thank you.... -
unable to login to Microsoft sites using windows hello PIN
in Windows Hello & Lockscreenunable to login to Microsoft sites using windows hello PIN: I know this is probably not the correct forum for this, but I was unable to find a more appropriate forum for this issue. I am trying to log into my Microsoft account to leave a comment on a Microsoft page, but for whatever reason, it is failing. My account is predates... -
Not able to login into windows using fingerprint, also Hello PIN is giving PIN Error...
in Windows Hello & LockscreenNot able to login into windows using fingerprint, also Hello PIN is giving PIN Error...: I am not able to login in my laptop since last week using fingerprint option. Earlier it was working fine. The system is not recognizing my fingerprint and also not showing any error. I tried registering the finger print again but sensor does not proceeds further. It just... -
Windows Hello & Pin Login NOT displaying on Login Screen
in Windows Hello & LockscreenWindows Hello & Pin Login NOT displaying on Login Screen: I have an HP Folio G1 laptop, which has a fingerprint reader. I have Windows 10 Pro version 1803 Build 17134.407. The only option on the login screen is for password. Both the pin and biometic (fingerprint) have disappeared. I'm not exactly sure when this has happened,... -
Problem with Login Picture screen
in Windows Hello & LockscreenProblem with Login Picture screen: I really like the pictures that Windows 10 puts up on the lock screen. However, the part that gives me the information about the picture and where it comes from and asks if I like it often doesn't come up. If I move my mouse or hit the space bar it brings up the screen to...
