Windows 10: Problem with my sound device
Discus and support Problem with my sound device in Windows 10 BSOD Crashes and Debugging to solve the problem; If I try to open any video or audio, both are not audible.The message popped up and show "We can't find an audio device" and "There might not be a... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by tushi15, Feb 9, 2019.
Problem with my sound device - Similar Threads - Problem sound device
Windows sound device problems
in Windows 10 GamingWindows sound device problems: I have a problem with the sound device. Everything was working fine. Then yesterday my entire sound device went away. Even the ones on my hdmi port. I finally found them in Device Manager under System Devices instead of Sound, Video, and Game Controller. This started after... -
in Windows 10 Software and AppsWindows sound device problems: I have a problem with the sound device. Everything was working fine. Then yesterday my entire sound device went away. Even the ones on my hdmi port. I finally found them in Device Manager under System Devices instead of Sound, Video, and Game Controller. This started after... -
in Windows 10 Drivers and HardwareWindows sound device problems: I have a problem with the sound device. Everything was working fine. Then yesterday my entire sound device went away. Even the ones on my hdmi port. I finally found them in Device Manager under System Devices instead of Sound, Video, and Game Controller. This started after... -
Sound problem "Audio device not found"
in Windows 10 GamingSound problem "Audio device not found": I lost my audio with the latest update on my Lenovo laptop. They worked fine before the update. I checked all the plugs etc. with no difference. Any suggestion is welcome?... -
in Windows 10 Software and AppsSound problem "Audio device not found": I lost my audio with the latest update on my Lenovo laptop. They worked fine before the update. I checked all the plugs etc. with no difference. Any suggestion is welcome?... -
in Windows 10 Drivers and HardwareSound problem "Audio device not found": I lost my audio with the latest update on my Lenovo laptop. They worked fine before the update. I checked all the plugs etc. with no difference. Any suggestion is welcome?... -
Sound problem with USB sound devices
in Windows 10 Ask InsiderSound problem with USB sound devices: Hey guys, I got myself 3 new audio devices Mic: Beyerdynamic Echo Fox USB Headphones: Beyerdynamic DT 990 PRO 250 OHM Soundcard: Fiio E10K Olympus 2 (connects via USB to PC) The Problem: If I'm using the FOX microphone with my 990 pros everything works just fine, but when... -
Windows Sound Device Problems
in Windows 10 Installation and UpgradeWindows Sound Device Problems: Hi everyone, I am having a problem with the sound device. Everything was working fine. Then one day my entire sound device was gone. Even those for my hdmi port. This started after the last Windows update. Also, my Realtek sound card is nowhere to be found. Thanks for help... -
USB PnP Sound Device problem
in Windows 10 Drivers and HardwareUSB PnP Sound Device problem: Hi, I have the USB PnP device so I can record to the computer with an aux connection. When I connect the USB device to the computer, it makes an annoying buzz noise. Can anyone help?...
